[Swift-devel] Swift trunk broken?
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb  7 12:03:42 CST 2011
Ooops. I didn't get any emails over the weekend (well, it seems I did,
but my otherwise reliable email notification didn't work). So I'm a bit
behind.
Mihael
On Fri, 2011-02-04 at 14:44 -0600, Michael Wilde wrote:
> Im getting strange errors from trunk at the moment from previously working scripts. Seemed to be unable to parse sites.xml.
> In the process of debugging this, I find that I cant get the simplest of swift scripts (a single trace statement) to run.
> Is anyone else encountering similar problems?
> Here's what I get:
> com$ cat hi.swift
> trace("hi");
> com$ java -version
> java version "1.6.0_20"
> Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
> Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
> com$ swift -version
> Swift svn swift-r4061 cog-r3046
> com$ swift hi.swift
> RunID: 20110204-1439-j430gp9g
> Progress:  time:0
> Execution failed:
>         1 names specified; 0 arguments found
> Time: 1.179, rate: 13896 j/s
> com$ cat hi.xml
> <program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
>          xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>          xmlns:xs="http://www.w3.org/2001/XMLSchema">
>   <call proc="trace" src="line 1">
>     <input><stringConstant>hi</stringConstant></input>
>   </call>
> </program>
> com$
> com$ cat *9g.log
> 2011-02-04 14:39:29,205-0600 DEBUG Loader Max heap: 238616576
> 2011-02-04 14:39:29,206-0600 DEBUG Loader kmlversion is >a1ce0de8-81e9-4226-987a-0bbcb40af008<
> 2011-02-04 14:39:29,207-0600 DEBUG Loader build version is >a1ce0de8-81e9-4226-987a-0bbcb40af008<
> 2011-02-04 14:39:29,207-0600 DEBUG Loader Recompilation suppressed.
> 2011-02-04 14:39:29,343-0600 INFO  VDL2ExecutionContext Stack dump:
> Level 1
> [iA = 0, iB = 0, bA = false, bB = false]
>         vdl:instanceconfig = Swift configuration []
>         vdl:operation = run
>         swift.home = /home/wilde/swift/rev/trunk/bin/..
>         PATH_SEPARATOR = /
> 2011-02-04 14:39:29,900-0600 INFO  unknown Using sites file: /home/wilde/swift/rev/trunk/bin/../etc/sites.xml
> 2011-02-04 14:39:29,928-0600 INFO  unknown Using tc.data: /home/wilde/swift/rev/trunk/bin/../etc/tc.data
> 2011-02-04 14:39:30,023-0600 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
> 2011-02-04 14:39:30,468-0600 INFO  unknown Swift svn swift-r4061 cog-r3046
> 2011-02-04 14:39:30,469-0600 INFO  unknown RUNID id=run:20110204-1439-j430gp9g
> 2011-02-04 14:39:30,511-0600 DEBUG VDL2ExecutionContext 1 names specified; 0 arguments found
>         at org.globus.cog.karajan.workflow.nodes.SetVar.post(SetVar.java:43)
>         at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
>         at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>         at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
>         at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>         at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>         at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>         at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>         at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
>         at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>         at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>         at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>         at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>         at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>         at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>         at java.lang.Thread.run(Thread.java:619)
> 2011-02-04 14:39:30,522-0600 INFO  ExecutionContext Detailed exception:
> 2011-02-04 14:39:30,522-0600 INFO  Loader Swift finished with errors
> com$
