[Swift-devel] Swift trunk broken?
Michael Wilde wilde at mcs.anl.gov
Fri Feb 4 14:44:33 CST 2011
Im getting strange errors from trunk at the moment from previously working scripts. Seemed to be unable to parse sites.xml.
In the process of debugging this, I find that I cant get the simplest of swift scripts (a single trace statement) to run.
Is anyone else encountering similar problems?
Here's what I get:
com$ cat hi.swift
trace("hi");
com$ java -version
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
com$ swift -version
Swift svn swift-r4061 cog-r3046
com$ swift hi.swift
RunID: 20110204-1439-j430gp9g
Progress:  time:0
Execution failed:
        1 names specified; 0 arguments found
Time: 1.179, rate: 13896 j/s
com$ cat hi.xml
<program xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xmlns:xs="http://www.w3.org/2001/XMLSchema">
  <call proc="trace" src="line 1">
    <input><stringConstant>hi</stringConstant></input>
  </call>
</program>
com$
com$ cat *9g.log
2011-02-04 14:39:29,205-0600 DEBUG Loader Max heap: 238616576
2011-02-04 14:39:29,206-0600 DEBUG Loader kmlversion is >a1ce0de8-81e9-4226-987a-0bbcb40af008<
2011-02-04 14:39:29,207-0600 DEBUG Loader build version is >a1ce0de8-81e9-4226-987a-0bbcb40af008<
2011-02-04 14:39:29,207-0600 DEBUG Loader Recompilation suppressed.
2011-02-04 14:39:29,343-0600 INFO  VDL2ExecutionContext Stack dump:
Level 1
[iA = 0, iB = 0, bA = false, bB = false]
        vdl:instanceconfig = Swift configuration []
        vdl:operation = run
        swift.home = /home/wilde/swift/rev/trunk/bin/..
        PATH_SEPARATOR = /
2011-02-04 14:39:29,900-0600 INFO  unknown Using sites file: /home/wilde/swift/rev/trunk/bin/../etc/sites.xml
2011-02-04 14:39:29,928-0600 INFO  unknown Using tc.data: /home/wilde/swift/rev/trunk/bin/../etc/tc.data
2011-02-04 14:39:30,023-0600 INFO  AbstractScheduler Setting resources to: {localhost=localhost}
2011-02-04 14:39:30,468-0600 INFO  unknown Swift svn swift-r4061 cog-r3046
2011-02-04 14:39:30,469-0600 INFO  unknown RUNID id=run:20110204-1439-j430gp9g
2011-02-04 14:39:30,511-0600 DEBUG VDL2ExecutionContext 1 names specified; 0 arguments found
        at org.globus.cog.karajan.workflow.nodes.SetVar.post(SetVar.java:43)
        at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
        at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
        at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
        at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
        at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
        at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
        at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
        at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
        at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
        at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
        at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
        at java.util.concurrent.FutureTask.run(FutureTask.java:138)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:619)
2011-02-04 14:39:30,522-0600 INFO  ExecutionContext Detailed exception:
2011-02-04 14:39:30,522-0600 INFO  Loader Swift finished with errors
com$
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
