[Swift-devel] swift on ranger
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Wed Dec 21 09:40:22 CST 2011
Should we provide an option to copy the submit file text into the log?
On Wed, 21 Dec 2011, David Kelly wrote:
> Sarah,
> Could you please send the submit files that were generated from this
> run? That should help narrow it down a bit.
> Thanks,
> David
>> From: "Sarah Kenny" <skenny at uci.edu>
>> To: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User" <swift-user at ci.uchicago.edu>
>> Sent: Wednesday, December 21, 2011 6:57:32 AM
>> Subject: [Swift-devel] swift on ranger
>> getting this when submitting to ranger with both the latest and our
>> previous version of swift (swift-r5259 cog-r3313)
>> Final status: time: Wed, 21 Dec 2011 04:49:15 -0800 Finished
>> successfully:100
>> The following warnings have occurred:
>> 1.
>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>> Cannot submit job: Could not submit job (qsub reported an exit code of
>> 1).
>> Welcome to TACC's Ranger System, an NSF XD Resource
>> Checking that you specified -V...--> Checking that you specified a
>> time limit...--> Checking that you specified a queue...--> Setting
>> project...--> Checking that you specified a parallel environment...-->
>> Checking that you specified a valid parallel environment name...-->
>> Checking that the minimum and maximum PE counts are the same...-->
>> Checking that the number of PEs requested is
>> valid...------------------> Rejecting job <------------------Your slot
>> (or core) request is not a multiple of 16.Syntax: -pe <pe_name>
>> <n>where <n> is a multiple of
>> 16.-----------------------------------------------------
>> Unable to run job: JSV rejected job.Exiting.
>> at
>> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
>> at
>> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
>> at
>> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
>> at
>> org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
>> Caused by:
>> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
>> Could not submit job (qsub reported an exit code of 1).
>> at
>> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:108)
>> at
>> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
>> ... 3 more
>> ################### sites file
>> <config>
>> <pool handle="RANGER">
>> <execution provider="coaster" jobManager="gt2:SGE" url="
>> gatekeeper.ranger.tacc.teragrid.org "/>
>> <filesystem provider="gsiftp" url="gsiftp://
>> gridftp.ranger.tacc.teragrid.org "/>
>> <profile namespace="globus" key="maxtime">86400</profile>
>> <profile namespace="globus" key="maxWallTime">02:00:00</profile>
>> <profile namespace="globus" key="jobsPerNode">1</profile>
>> <profile namespace="globus" key="nodeGranularity">64</profile>
>> <profile namespace="globus" key="maxNodes">4096</profile>
>> <profile namespace="globus" key="queue">normal</profile>
>> <profile namespace="karajan" key="jobThrottle">1.28</profile>
>> <profile namespace="globus" key="project">TG-DBS080004N</profile>
>> <profile namespace="globus" key="pe">16way</profile>
>> <profile namespace="karajan" key="initialScore">10000</profile>
>> <workdirectory>/work/00043/tg457040/swiftwork</workdirectory>
>> </pool>
>> </config>
>> same settings we've been using for a while, i'm not sure why this
>> seems to be popping up now, but it's rather consistent. all jobs are
>> finishing successfully, so it's rather confusing...any idea what i
>> might be missing here?
>> thanks
>> ~sk
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
