[Swift-devel] swift on ranger
David Kelly
davidk at ci.uchicago.edu
Wed Dec 21 08:55:18 CST 2011
Sarah,
Could you please send the submit files that were generated from this run? That should help narrow it down a bit.
David
----- Original Message -----
> From: "Sarah Kenny" <skenny at uci.edu>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User" <swift-user at ci.uchicago.edu>
> Sent: Wednesday, December 21, 2011 6:57:32 AM
> Subject: [Swift-devel] swift on ranger
> getting this when submitting to ranger with both the latest and our
> previous version of swift (swift-r5259 cog-r3313)
> Final status: time: Wed, 21 Dec 2011 04:49:15 -0800 Finished
> successfully:100
> The following warnings have occurred:
> 1.
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job: Could not submit job (qsub reported an exit code of
> 1).
> Welcome to TACC's Ranger System, an NSF XD Resource
> Checking that you specified -V...--> Checking that you specified a
> time limit...--> Checking that you specified a queue...--> Setting
> project...--> Checking that you specified a parallel environment...-->
> Checking that you specified a valid parallel environment name...-->
> Checking that the minimum and maximum PE counts are the same...-->
> Checking that the number of PEs requested is
> valid...------------------> Rejecting job <------------------Your slot
> (or core) request is not a multiple of 16.Syntax: -pe <pe_name>
> <n>where <n> is a multiple of
> 16.-----------------------------------------------------
> Unable to run job: JSV rejected job.Exiting.
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> Caused by:
> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
> Could not submit job (qsub reported an exit code of 1).
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:108)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> ... 3 more
> ################### sites file
> <config>
> <pool handle="RANGER">
> <execution provider="coaster" jobManager="gt2:SGE" url="
> gatekeeper.ranger.tacc.teragrid.org "/>
> <filesystem provider="gsiftp" url="gsiftp://
> gridftp.ranger.tacc.teragrid.org "/>
> <profile namespace="globus" key="maxtime">86400</profile>
> <profile namespace="globus" key="maxWallTime">02:00:00</profile>
> <profile namespace="globus" key="jobsPerNode">1</profile>
> <profile namespace="globus" key="nodeGranularity">64</profile>
> <profile namespace="globus" key="maxNodes">4096</profile>
> <profile namespace="globus" key="queue">normal</profile>
> <profile namespace="karajan" key="jobThrottle">1.28</profile>
> <profile namespace="globus" key="project">TG-DBS080004N</profile>
> <profile namespace="globus" key="pe">16way</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <workdirectory>/work/00043/tg457040/swiftwork</workdirectory>
> </pool>
> </config>
> same settings we've been using for a while, i'm not sure why this
> seems to be popping up now, but it's rather consistent. all jobs are
> finishing successfully, so it's rather confusing...any idea what i
> might be missing here?
> thanks
> ~sk
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
