[Swift-devel] modftdock - all 3 stages
Emalayan Vairavanathan svemalayan at yahoo.com
Fri Dec 2 13:20:44 CST 2011
Hi Ketan,
Thank you very much for the reply. I will ask you if I have more questions.
Regards
Emalayan
 From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: Swift Devel <swift-devel at ci.uchicago.edu>
Sent: Thursday, 1 December 2011 2:49 PM
Subject: Re: modftdock - all 3 stages
On Thu, Dec 1, 2011 at 10:17 AM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
Hi Ketan,
>I have a quick question.
>We are trying to configure MosaStore for an application with multiple data flow patterns. Currently we cannot have some of these optimizations together in MosaStore. So we decided have two MosaStore instances with optimizations in our experiments.
>I am curious to know whether is it possible to run swift programs with the multiple Mosa installations ? ( may be is there a way to specify multiple working directories in swift ? / May be can I dynamically change the swift working directory ?)
cc'ing swift-devel, for more input. My answer below:
Having one working directory should not be an issue with what you want to achieve, as long as that workdir is accessible to and from the mosastore instaces you mentioned above. All you need to do is to change the mappings in the Swift source to the places you want swift to access/write data. So, for instance, for one part you can use one instance of mosastore while for the other part you can use another mosastore instance.
>Thank you
>Emalayan
>________________________________
>Sent: Monday, 28 November 2011 6:47 AM
>Emalayan,
>Do you have access to this svn: https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/modFTDock
>Try to check out, you will find the three stage modFTDock Swift script and the related binaries.
>Regards,
>Ketan
>On Sun, Nov 27, 2011 at 2:13 PM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
>Hi Ketan,
>>We are trying to run  all the stages of ModFTDock with Mosastore.  Could you please let me know how I can run the modemerge and score stages ?
>>In case if you already have a working installation of modftdock, we will be very happy to try that.
>>Thank you
>>Emalayan
>Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111202/43b9864e/attachment.html>
