[Swift-devel] Could not convert value to boolean
Ketan Maheshwari ketancmaheshwari at gmail.com
Fri Dec 2 15:40:53 CST 2011
Hello,
Today, I saw this error in a simple catsn script running from engage submit
host to OSG via GWMS.
The run involved 98 tasks out of which 2 failed with the error message:
Caused by: org.globus.cog.karajan.workflow.KarajanRuntimeException: Could
not convert value to boolean: null
at org.globus.cog.karajan.util.TypeUtil.toBoolean(TypeUtil.java:127)
at org.griphyn.vdl.karajan.lib.Mark.function(Mark.java:30)
at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:62)
at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
at
org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
This does not happen in each run. Out of 4 such runs that I tried, it
happened in one run.
The complete log is here:
http://www.mcs.anl.gov/~ketan/catsn-20111202-1627-0e9196p8.log
In the log, I see a couple of "Broken pipe" messages but am not sure if the
two are related in any ways.
I had 50 workers running.
The coaster service log is:  http://www.mcs.anl.gov/~ketan/swift.log
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20111202/02d2595d/attachment.html>
