[Swift-devel] Notes from 0.93 meeting
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 16:46:26 CDT 2011
True.  I did not think that each mechanism would use different CAs.  We might want to ask ci support to update the grid certs more frequently then to avoid this situation.
On Aug 25, 2011, at 4:42 PM, Mihael Hategan wrote:
> On Thu, 2011-08-25 at 16:40 -0500, Jonathan Monette wrote:
>> That is weird.  If you were able to gsissh to ranger I would assume
>> that you are able to globus-url-copy to ranger.
> Not if the two use different CAs. Or if a password was typed at the ssh
> login.
>>  Anyways, what Sarah said should work.  I would assume that ci would
>> update more frequently to avoid this problem.
>> On Aug 25, 2011, at 4:38 PM, Sarah Kenny wrote:
>>> communicado's certs (/etc/grid-security/certificates) are
>>> out-of-date...if you copy ranger's /etc/grid-security/certificates
>>> directory to communicado and point yr X509_CERT_DIR to it you can
>>> get a job thru (a simple globus-job-run with my vaild cert fails
>>> from communicado at the moment if i don't do this).
>>> i set our machines at uci to update daily...i think it's less
>>> frequently at ci...
>>> On Thu, Aug 25, 2011 at 2:17 PM, Mihael Hategan
>>> <hategan at mcs.anl.gov> wrote:
>>>        Can you try a globus-url-copy to gridftp.ranger?
>>>        gridftp.ranger seems to have the NCSA myproxy CA. You say
>>>        you have the
>>>        proper certificates dir in your X509_CERT_DIR, and that
>>>        directory
>>>        contains the TACC root cert. So it should work. And so
>>>        should swift.
>>>        Though I think that jglobus should be more clear about
>>>        "Unknown ca"
>>>        errors. At least the name of the unknown CA should be part
>>>        of the error
>>>        message.
>>>        On Thu, 2011-08-25 at 15:55 -0500, David Kelly wrote:
>>>> $ grid-proxy-info -all
>>>> subject  : /C=US/O=National Center for Supercomputing
>>>        Applications/CN=David Kelly
>>>> issuer   : /C=US/O=National Center for Supercomputing
>>>        Applications/OU=Certificate Authorities/CN=MyProxy
>>>> identity : /C=US/O=National Center for Supercomputing
>>>> type     : end entity credential
>>>> strength : 1024 bits
>>>> path     : /tmp/x509up_u1878
>>>> timeleft : 9:56:53
>>>> ----- Original Message -----
>>>>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>>>>> To: "David Kelly" <davidk at ci.uchicago.edu>
>>>>> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>,
>>>        "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>>>>> Sent: Thursday, August 25, 2011 3:42:57 PM
>>>>> Subject: Re: [Swift-devel] Notes from 0.93 meeting
>>>>> Odd. Can you paste the output of 'grid-proxy-info -all'?
>>>>> On Thu, 2011-08-25 at 15:18 -0500, David Kelly wrote:
>>>>>> Sure, here is the full log:
>>>        http://www.ci.uchicago.edu/~davidk/001-catsn-ranger-20110825-1515-5tydro91.log
>>>        "swift-devel
>>>>>>> Sent: Thursday, August 25, 2011 2:43:31 PM
>>>>>>> It's possible that the CA dir on Ranger is not
>>>        properly set up.
>>>>>>> Can
>>>>>>> you
>>>>>>> post the full log?
>>>>>>> On Thu, 2011-08-25 at 13:56 -0500, David Kelly
>>>        wrote:
>>>>>>>> Those environment variables were not set up. I
>>>        have them defined
>>>>>>>> now, but I'm still getting the same error.
>>>>>>>> [davidk at communicado ranger]$ env |grep 509
>>>>>>>> X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>>>>>>>> X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>>>>>>>> [davidk at communicado ranger]$ swift -sites.file
>>>        sites.xml
>>>>>>>> -tc.file
>>>>>>>> tc.data 001-catsn-ranger.swift
>>>>>>>> Swift svn swift-r4987 (swift modified locally)
>>>        cog-r3229
>>>>>>>> RunID: 20110825-1352-f1v940b4
>>>>>>>> Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
>>>>>>>> Progress: time: Thu, 25 Aug 2011 13:53:00 -0500
>>>        Selecting site:7
>>>>>>>> Initializing site shared directory:3
>>>>>>>> Execution failed:
>>>>>>>>      Authentication failed [Caused by: Failure
>>>        unspecified at
>>>>>>>>      GSS-API
>>>>>>>>      level [Caused by: Unknown CA]]
>>>>>>>>> From: "Ketan Maheshwari"
>>>>>>>>> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>,
>>>        "swift-devel
>>>>>>>>> Devel"
>>>>>>>>> Sent: Thursday, August 25, 2011 1:32:50 PM
>>>        meeting
>>>>>>>>> Hi,
>>>>>>>>> Are your CADIR and CACERT env vars set up?
>>>>>>>>> [communicado:swiftgrid]$ echo $X509_CADIR
>>>>>>>>> [communicado:swiftgrid]$ echo $X509_CERT_DIR
>>>>>>>>> On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
>>>>>>>>>> wrote:
>>>>>>>>> Thanks Jon,
>>>>>>>>> Here is what happens when I try this from
>>>        communicado:
>>>>>>>>> [davidk at communicado ~]$ myproxy-logon -l dkelly
>>>        -s
>>>>>>>>> myproxy.teragrid.org
>>>>>>>>> Enter MyProxy pass phrase:
>>>>>>>>> A credential has been received for user dkelly
>>>        in
>>>>>>>>> /tmp/x509up_u1878.
>>>        sites.xml
>>>>>>>>> -tc.file
>>>        cog-r3229
>>>>>>>>> RunID: 20110825-1326-o3e38fe0
>>>>>>>>> Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
>>>>>>>>> Progress: time: Thu, 25 Aug 2011 13:26:44 -0500
>>>        Selecting
>>>>>>>>> site:8
>>>>>>>>> Initializing site shared directory:2
>>>>>>>>> Execution failed:
>>>        unspecified at
>>>>>>>>> GSS-API
>>>>>>>>> level
>>>>>>>>> Any ideas?
>>>>>>>>> Thanks,
>>>>>>>>> David
>>>>>>>>> _______________________________________________
>>>>>>>>> Swift-devel mailing list
>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>        https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>>>>>>> Ketan
>>> Sarah Kenny
>>> Programmer ~ Brain Circuits Laboratory ~ Rm 2224 Bio Sci III
>>> University of California Irvine, Dept. of Neurology ~ 773-818-8300
