[Swift-devel] Notes from 0.93 meeting
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 16:42:58 CDT 2011
On Thu, 2011-08-25 at 16:40 -0500, Jonathan Monette wrote:
> That is weird.  If you were able to gsissh to ranger I would assume
> that you are able to globus-url-copy to ranger.
Not if the two use different CAs. Or if a password was typed at the ssh
login.
>   Anyways, what Sarah said should work.  I would assume that ci would
> update more frequently to avoid this problem.
> On Aug 25, 2011, at 4:38 PM, Sarah Kenny wrote:
> > communicado's certs (/etc/grid-security/certificates) are
> > out-of-date...if you copy ranger's /etc/grid-security/certificates
> > directory to communicado and point yr X509_CERT_DIR to it you can
> > get a job thru (a simple globus-job-run with my vaild cert fails
> > from communicado at the moment if i don't do this).
> > i set our machines at uci to update daily...i think it's less
> > frequently at ci...
> > On Thu, Aug 25, 2011 at 2:17 PM, Mihael Hategan
> > <hategan at mcs.anl.gov> wrote:
> >         Can you try a globus-url-copy to gridftp.ranger?
> >         gridftp.ranger seems to have the NCSA myproxy CA. You say
> >         you have the
> >         proper certificates dir in your X509_CERT_DIR, and that
> >         directory
> >         contains the TACC root cert. So it should work. And so
> >         should swift.
> >         Though I think that jglobus should be more clear about
> >         "Unknown ca"
> >         errors. At least the name of the unknown CA should be part
> >         of the error
> >         message.
> >         On Thu, 2011-08-25 at 15:55 -0500, David Kelly wrote:
> >         > $ grid-proxy-info -all
> >         > subject  : /C=US/O=National Center for Supercomputing
> >         Applications/CN=David Kelly
> >         > issuer   : /C=US/O=National Center for Supercomputing
> >         Applications/OU=Certificate Authorities/CN=MyProxy
> >         > identity : /C=US/O=National Center for Supercomputing
> >         > type     : end entity credential
> >         > strength : 1024 bits
> >         > path     : /tmp/x509up_u1878
> >         > timeleft : 9:56:53
> >         > ----- Original Message -----
> >         > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> >         > > To: "David Kelly" <davidk at ci.uchicago.edu>
> >         > > Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>,
> >         "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> >         > > Sent: Thursday, August 25, 2011 3:42:57 PM
> >         > > Subject: Re: [Swift-devel] Notes from 0.93 meeting
> >         > > Odd. Can you paste the output of 'grid-proxy-info -all'?
> >         > > On Thu, 2011-08-25 at 15:18 -0500, David Kelly wrote:
> >         > > > Sure, here is the full log:
> >         http://www.ci.uchicago.edu/~davidk/001-catsn-ranger-20110825-1515-5tydro91.log
> >         "swift-devel
> >         > > > > Sent: Thursday, August 25, 2011 2:43:31 PM
> >         > > > > It's possible that the CA dir on Ranger is not
> >         properly set up.
> >         > > > > Can
> >         > > > > you
> >         > > > > post the full log?
> >         > > > > On Thu, 2011-08-25 at 13:56 -0500, David Kelly
> >         wrote:
> >         > > > > > Those environment variables were not set up. I
> >         have them defined
> >         > > > > > now, but I'm still getting the same error.
> >         > > > > > [davidk at communicado ranger]$ env |grep 509
> >         > > > > > X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> >         > > > > > X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> >         > > > > > [davidk at communicado ranger]$ swift -sites.file
> >         sites.xml
> >         > > > > > -tc.file
> >         > > > > > tc.data 001-catsn-ranger.swift
> >         > > > > > Swift svn swift-r4987 (swift modified locally)
> >         cog-r3229
> >         > > > > > RunID: 20110825-1352-f1v940b4
> >         > > > > > Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
> >         > > > > > Progress: time: Thu, 25 Aug 2011 13:53:00 -0500
> >         Selecting site:7
> >         > > > > > Initializing site shared directory:3
> >         > > > > > Execution failed:
> >         > > > > >       Authentication failed [Caused by: Failure
> >         unspecified at
> >         > > > > >       GSS-API
> >         > > > > >       level [Caused by: Unknown CA]]
> >         > > > > > > From: "Ketan Maheshwari"
> >         > > > > > > Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>,
> >         "swift-devel
> >         > > > > > > Devel"
> >         > > > > > > Sent: Thursday, August 25, 2011 1:32:50 PM
> >         meeting
> >         > > > > > > Hi,
> >         > > > > > > Are your CADIR and CACERT env vars set up?
> >         > > > > > > [communicado:swiftgrid]$ echo $X509_CADIR
> >         > > > > > > [communicado:swiftgrid]$ echo $X509_CERT_DIR
> >         > > > > > > On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
> >         > > > > > > > wrote:
> >         > > > > > > Thanks Jon,
> >         > > > > > > Here is what happens when I try this from
> >         communicado:
> >         > > > > > > [davidk at communicado ~]$ myproxy-logon -l dkelly
> >         -s
> >         > > > > > > myproxy.teragrid.org
> >         > > > > > > Enter MyProxy pass phrase:
> >         > > > > > > A credential has been received for user dkelly
> >         in
> >         > > > > > > /tmp/x509up_u1878.
> >         sites.xml
> >         > > > > > > -tc.file
> >         cog-r3229
> >         > > > > > > RunID: 20110825-1326-o3e38fe0
> >         > > > > > > Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
> >         > > > > > > Progress: time: Thu, 25 Aug 2011 13:26:44 -0500
> >         Selecting
> >         > > > > > > site:8
> >         > > > > > > Initializing site shared directory:2
> >         > > > > > > Execution failed:
> >         unspecified at
> >         > > > > > > GSS-API
> >         > > > > > > level
> >         > > > > > > Any ideas?
> >         > > > > > > Thanks,
> >         > > > > > > David
> >         > > > > > > _______________________________________________
> >         > > > > > > Swift-devel mailing list
> >         > > > > > > Swift-devel at ci.uchicago.edu
> >         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >         > > > > > > Ketan
> > Sarah Kenny
> > Programmer ~ Brain Circuits Laboratory ~ Rm 2224 Bio Sci III
> > University of California Irvine, Dept. of Neurology ~ 773-818-8300
