[Swift-devel] Notes from 0.93 meeting
    David Kelly
    davidk at ci.uchicago.edu
    Thu Aug 25 15:18:49 CDT 2011
Sure, here is the full log:
http://www.ci.uchicago.edu/~davidk/001-catsn-ranger-20110825-1515-5tydro91.log
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, August 25, 2011 2:43:31 PM
> Subject: Re: [Swift-devel] Notes from 0.93 meeting
> It's possible that the CA dir on Ranger is not properly set up. Can
> you
> post the full log?
> On Thu, 2011-08-25 at 13:56 -0500, David Kelly wrote:
> > Those environment variables were not set up. I have them defined
> > now, but I'm still getting the same error.
> > [davidk at communicado ranger]$ env |grep 509
> > X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> > X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> > [davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file
> > tc.data 001-catsn-ranger.swift
> > Swift svn swift-r4987 (swift modified locally) cog-r3229
> > RunID: 20110825-1352-f1v940b4
> > Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
> > Progress: time: Thu, 25 Aug 2011 13:53:00 -0500 Selecting site:7
> > Initializing site shared directory:3
> > Execution failed:
> > 	Authentication failed [Caused by: Failure unspecified at GSS-API
> > 	level [Caused by: Unknown CA]]
> > > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > > Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "swift-devel Devel"
> > > Sent: Thursday, August 25, 2011 1:32:50 PM
> > > Hi,
> > > Are your CADIR and CACERT env vars set up?
> > > [communicado:swiftgrid]$ echo $X509_CADIR
> > > [communicado:swiftgrid]$ echo $X509_CERT_DIR
> > > On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
> > > > wrote:
> > > Thanks Jon,
> > > Here is what happens when I try this from communicado:
> > > [davidk at communicado ~]$ myproxy-logon -l dkelly -s
> > > myproxy.teragrid.org
> > > Enter MyProxy pass phrase:
> > > A credential has been received for user dkelly in
> > > /tmp/x509up_u1878.
> > > RunID: 20110825-1326-o3e38fe0
> > > Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
> > > Progress: time: Thu, 25 Aug 2011 13:26:44 -0500 Selecting site:8
> > > Initializing site shared directory:2
> > > Execution failed:
> > > level
> > > Any ideas?
> > > Thanks,
> > > David
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > > Ketan
