[Swift-devel] Notes from 0.93 meeting
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 25 14:43:31 CDT 2011
It's possible that the CA dir on Ranger is not properly set up. Can you
post the full log?
On Thu, 2011-08-25 at 13:56 -0500, David Kelly wrote:
> Those environment variables were not set up. I have them defined now, but I'm still getting the same error.
> [davidk at communicado ranger]$ env |grep 509
> X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> [davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file tc.data 001-catsn-ranger.swift
> Swift svn swift-r4987 (swift modified locally) cog-r3229
> RunID: 20110825-1352-f1v940b4
> Progress:  time: Thu, 25 Aug 2011 13:52:59 -0500
> Progress:  time: Thu, 25 Aug 2011 13:53:00 -0500  Selecting site:7  Initializing site shared directory:3
> Execution failed:
> 	Authentication failed [Caused by: Failure unspecified at GSS-API level [Caused by: Unknown CA]]
> > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > To: "David Kelly" <davidk at ci.uchicago.edu>
> > Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Thursday, August 25, 2011 1:32:50 PM
> > Subject: Re: [Swift-devel] Notes from 0.93 meeting
> > Hi,
> > Are your CADIR and CACERT env vars set up?
> > [communicado:swiftgrid]$ echo $X509_CADIR
> > [communicado:swiftgrid]$ echo $X509_CERT_DIR
> > On Thu, Aug 25, 2011 at 1:29 PM, David Kelly < davidk at ci.uchicago.edu
> > > wrote:
> > Thanks Jon,
> > Here is what happens when I try this from communicado:
> > [davidk at communicado ~]$ myproxy-logon -l dkelly -s
> > myproxy.teragrid.org
> > Enter MyProxy pass phrase:
> > A credential has been received for user dkelly in /tmp/x509up_u1878.
> > RunID: 20110825-1326-o3e38fe0
> > Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
> > Progress: time: Thu, 25 Aug 2011 13:26:44 -0500 Selecting site:8
> > Initializing site shared directory:2
> > Execution failed:
> > Any ideas?
> > Thanks,
> > David
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Ketan
