[Swift-devel] Notes from 0.93 meeting
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Aug 25 14:24:10 CDT 2011
I am not sure it matter(but it might) but this is the login node for teragrid on ranger.  tg-login.ranger.tacc.teragrid.org.   You requested a proxy from myproxy-login with username=dkelly.  If you want to use the proxy on ranger think the command should have been 'myproxy-login -l davidkel -s myproxy.teragrid.org'.
On Aug 25, 2011, at 2:21 PM, David Kelly wrote:
> Yes, I can gsissh into davidkel at ranger.tacc.utexas.edu with that proxy. One weird thing to note - my username on communicado is davidk, my username for teragrid is dkelly, and my username on ranger is davidkel. I don't think that would cause the CA error, but thought I should mention it.
> David
>> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> To: "David Kelly" <davidk at ci.uchicago.edu>
>> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Thursday, August 25, 2011 2:03:37 PM
>> Subject: Re: [Swift-devel] Notes from 0.93 meeting
>> With that proxy can you gsissh to ranger?
>> On Aug 25, 2011, at 1:56 PM, David Kelly wrote:
>>> Those environment variables were not set up. I have them defined
>>> now, but I'm still getting the same error.
>>> [davidk at communicado ranger]$ env |grep 509
>>> X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>>> X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
>>> [davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file
>>> tc.data 001-catsn-ranger.swift
>>> Swift svn swift-r4987 (swift modified locally) cog-r3229
>>> RunID: 20110825-1352-f1v940b4
>>> Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
>>> Progress: time: Thu, 25 Aug 2011 13:53:00 -0500 Selecting site:7
>>> Initializing site shared directory:3
>>> Execution failed:
>>> 	Authentication failed [Caused by: Failure unspecified at GSS-API
>>> 	level [Caused by: Unknown CA]]
>>>> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
>>>> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "swift-devel Devel"
>>>> Sent: Thursday, August 25, 2011 1:32:50 PM
>>>> Hi,
>>>> Are your CADIR and CACERT env vars set up?
>>>> [communicado:swiftgrid]$ echo $X509_CADIR
>>>> [communicado:swiftgrid]$ echo $X509_CERT_DIR
>>>> On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
>>>>> wrote:
>>>> Thanks Jon,
>>>> Here is what happens when I try this from communicado:
>>>> [davidk at communicado ~]$ myproxy-logon -l dkelly -s
>>>> Enter MyProxy pass phrase:
>>>> A credential has been received for user dkelly in
>>>> /tmp/x509up_u1878.
>>>> RunID: 20110825-1326-o3e38fe0
>>>> Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
>>>> Progress: time: Thu, 25 Aug 2011 13:26:44 -0500 Selecting site:8
>>>> Initializing site shared directory:2
>>>> Execution failed:
>>>> level
>>>> Any ideas?
>>>> Thanks,
>>>> David
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>>> Ketan
