[Swift-devel] Notes from 0.93 meeting
    David Kelly
    davidk at ci.uchicago.edu
    Thu Aug 25 14:21:47 CDT 2011
Yes, I can gsissh into davidkel at ranger.tacc.utexas.edu with that proxy. One weird thing to note - my username on communicado is davidk, my username for teragrid is dkelly, and my username on ranger is davidkel. I don't think that would cause the CA error, but thought I should mention it.
David
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, August 25, 2011 2:03:37 PM
> Subject: Re: [Swift-devel] Notes from 0.93 meeting
> With that proxy can you gsissh to ranger?
> On Aug 25, 2011, at 1:56 PM, David Kelly wrote:
> > Those environment variables were not set up. I have them defined
> > now, but I'm still getting the same error.
> > [davidk at communicado ranger]$ env |grep 509
> > X509_CERT_DIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> > X509_CADIR=/opt/osg-1.2.16/globus/TRUSTED_CA
> > [davidk at communicado ranger]$ swift -sites.file sites.xml -tc.file
> > tc.data 001-catsn-ranger.swift
> > Swift svn swift-r4987 (swift modified locally) cog-r3229
> > RunID: 20110825-1352-f1v940b4
> > Progress: time: Thu, 25 Aug 2011 13:52:59 -0500
> > Progress: time: Thu, 25 Aug 2011 13:53:00 -0500 Selecting site:7
> > Initializing site shared directory:3
> > Execution failed:
> > 	Authentication failed [Caused by: Failure unspecified at GSS-API
> > 	level [Caused by: Unknown CA]]
> >> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> >> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "swift-devel Devel"
> >> Sent: Thursday, August 25, 2011 1:32:50 PM
> >> Hi,
> >> Are your CADIR and CACERT env vars set up?
> >> [communicado:swiftgrid]$ echo $X509_CADIR
> >> [communicado:swiftgrid]$ echo $X509_CERT_DIR
> >> On Thu, Aug 25, 2011 at 1:29 PM, David Kelly <
> >>> wrote:
> >> Thanks Jon,
> >> Here is what happens when I try this from communicado:
> >> [davidk at communicado ~]$ myproxy-logon -l dkelly -s
> >> myproxy.teragrid.org
> >> Enter MyProxy pass phrase:
> >> A credential has been received for user dkelly in
> >> /tmp/x509up_u1878.
> >> RunID: 20110825-1326-o3e38fe0
> >> Progress: time: Thu, 25 Aug 2011 13:26:43 -0500
> >> Progress: time: Thu, 25 Aug 2011 13:26:44 -0500 Selecting site:8
> >> Initializing site shared directory:2
> >> Execution failed:
> >> level
> >> Any ideas?
> >> Thanks,
> >> David
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >> Ketan
