[Swift-devel] Index out of bounds
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Aug 22 21:47:05 CDT 2011
On Mon, 2011-08-22 at 21:37 -0500, Jonathan Monette wrote:
> Ok.  I have ran the test case after updating the and rebuilding the
> 0.93 release.  I am not sure why the IndexOutOfBounds error was
> appearing but now it is not.
Ok, then I might know. Was any of your files over 2G in size?
>  I have ran my scripts around 10 times and the error has not appeared.
> I am not really sure what happened but I cannot reproduce the error.
> I am not sure why it was appearing in the first place.
> On Aug 20, 2011, at 9:03 PM, Michael Wilde wrote:
> > Jon,  the list you want for Beagle issue notifications is
> > beagle-users. You can subscribe via the link:
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/beagle-users
> > - Mike
> > ----- Forwarded Message -----
> > From: "Greg Cross" <grog at ci.uchicago.edu>
> > To: beagle-users at ci.uchicago.edu
> > Sent: Saturday, August 20, 2011 2:12:45 PM
> > Subject: [beagle-users] Outage update
> > Lustre is mounting properly but there is a communication failure
> > between the Moab and ALPS scheduler components.  This issue is under
> > investigation and has been escalated to Cray.
> > As a reminder, please DO NOT attempt to log into the system during
> > this or any other maintenance period.  While logins should be denied
> > at this time, any user processes found running on login or sandbox
> > nodes will be terminated without warning.  Users who do not respect
> > this may be contacted individually.
> > Definitive notification will be sent to this mailing list when the
> > system is available for use.
> > _______________________________________________
> > beagle-users mailing list
> > ____________________________________________________________________
> >         From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> >         To: "Daniel S. Katz" <dsk at ci.uchicago.edu>
> >         Cc: swift-devel at ci.uchicago.edu
> >         Sent: Saturday, August 20, 2011 4:20:35 PM
> >         Subject: Re: [Swift-devel] Index out of bounds
> >         Thanks. In the meantime could someone let me know when
> >         beagle is back in production so I can check my run?
> >         ----- Reply message -----
> >         From: "Daniel S. Katz" <dsk at ci.uchicago.edu>
> >         Date: Sat, Aug 20, 2011 3:14 pm
> >         Subject: [Swift-devel] Index out of bounds
> >         To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> >         Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>,
> >         "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>
> >         Yes, write to beagle-support.
> >         On Aug 20, 2011, at 14:52, "Jonathan Monette"
> >         <jonmon at mcs.anl.gov> wrote:
> >                 Ok thanks. It seems that I was not added to the
> >                 beagle-notify list. Could someone point me to a link
> >                 I can subscribe to? Or do I subscribe by sending
> >                 mail to beagle-support?
> >                 From: "Ketan Maheshwari"
> >                 Date: Sat, Aug 20, 2011 7:45 am
> >                 Cc: <swift-devel at ci.uchicago.edu>
> >                 Yes, Beagle went down yesterday. There was a notice.
> >                 Current status as of Aug 19, 5.30PM:
> >                 At this time, Lustre is not starting properly on
> >                 Beagle.  This may be related to a configuration
> >                 change that was made during the last outage.  The
> >                 effort to restore system availability is still in
> >                 active progress.
> >                 Ketan
> >                 On Sat, Aug 20, 2011 at 12:03 AM, Jonathan
> >                 Monette <jonmon at mcs.anl.gov> wrote:
> >                         I updated and rebuilt and added that line to
> >                         my log4j properties.  Does anyone know if
> >                         Beagle is down?  showq says there is no
> >                         service listening to sdb:<number>.  qstat
> >                         shows that I have a job sitting in the queue
> >                         but it doesn't look like jobs are running.
> >                         I am using both PADS and Beagle for this
> >                         execution.  In this case where jobs are not
> >                         executing on Beagle shouldn't Swift start
> >                         submitting jobs to PADS?  I do not see that
> >                         behavior.
> >                         This run is still executing.  But if you
> >                         would like to look at the log it is
> >                         at www.ci.uchicago.edu/~jonmon/logs/montage-2.log.  Only 23 tasks have finished before it just sits there waiting for Beagle to run.
> >                         On Aug 19, 2011, at 2:46 PM, Jonathan
> >                         Monette wrote:
> >                         > Sure can. I add that line to the log4j
> >                         file or in a different properties file.
> >                         > From: "Mihael Hategan"
> >                         <hategan at mcs.anl.gov>
> >                         > Date: Fri, Aug 19, 2011 2:03 pm
> >                         > Subject: Index out of bounds
> >                         > Hmm. So I can't see how this manages to
> >                         happen.
> >                         > I added some checks and debugging
> >                         statements. Can you update, set log
> >                         > level of
> >                         org.globus.cog.abstraction.impl.file.local
> >                         to DEBUG, re-run and
> >                         > then post the log when the exception pops
> >                         up?
> >                         > Mihael
> >                         > On Thu, 2011-08-18 at 23:14 -0500,
> >                         > > Ok.  The log is at
> >                         > www.ci.uchicago.edu/~jonmon/logs/montage-1.log
> >                         > > On Aug 18, 2011, at 5:56 PM, Mihael
> >                         Hategan wrote:
> >                         > > > It's probably a good idea to post the
> >                         stack trace of that exception now
> >                         > > > rather than later.
> >                         > > > On Thu, 2011-08-18 at 13:09 -0500,
> >                         > > >> Hello,
> >                         > > >>  I was running 0.93 with one a
> >                         relatively small run, a 350 task run.
> >                         > > >> The run failed on one of the final
> >                         tasks. I checked the log file and
> >                         > > >> saw some index out of bounds errors.
> >                         I tried with a smaller run and
> >                         > > >> didn't see the error.
> >                         > > >> This run was using beagle, pads, and
> >                         communicado. I was also using
> >                         > > >> cdm. I will post the log in a bit. I
> >                         am seeing if I cam replicate it
> >                         > > >> without using cdm and with a smaller
> >                         site pool.
> >                         > Swift-devel mailing list
> >                         > Swift-devel at ci.uchicago.edu
> >                         > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> >                 Ketan
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
