[Swift-devel] Index out of bounds
    Jonathan Monette
    jonmon at mcs.anl.gov
    Mon Aug 22 21:37:22 CDT 2011
Ok.  I have ran the test case after updating the and rebuilding the 0.93 release.  I am not sure why the IndexOutOfBounds error was appearing but now it is not.  I have ran my scripts around 10 times and the error has not appeared.  I am not really sure what happened but I cannot reproduce the error.  I am not sure why it was appearing in the first place.
On Aug 20, 2011, at 9:03 PM, Michael Wilde wrote:
> Jon,  the list you want for Beagle issue notifications is beagle-users. You can subscribe via the link:
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/beagle-users
> - Mike
> ----- Forwarded Message -----
> From: "Greg Cross" <grog at ci.uchicago.edu>
> To: beagle-users at ci.uchicago.edu
> Sent: Saturday, August 20, 2011 2:12:45 PM
> Subject: [beagle-users] Outage update
> Lustre is mounting properly but there is a communication failure between the Moab and ALPS scheduler components.  This issue is under investigation and has been escalated to Cray.
> As a reminder, please DO NOT attempt to log into the system during this or any other maintenance period.  While logins should be denied at this time, any user processes found running on login or sandbox nodes will be terminated without warning.  Users who do not respect this may be contacted individually.
> Definitive notification will be sent to this mailing list when the system is available for use.
> beagle-users mailing list
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "Daniel S. Katz" <dsk at ci.uchicago.edu>
> Cc: swift-devel at ci.uchicago.edu
> Sent: Saturday, August 20, 2011 4:20:35 PM
> Subject: Re: [Swift-devel] Index out of bounds
> Thanks. In the meantime could someone let me know when beagle is back in production so I can check my run?
> ----- Reply message -----
> From: "Daniel S. Katz" <dsk at ci.uchicago.edu>
> Date: Sat, Aug 20, 2011 3:14 pm
> Subject: [Swift-devel] Index out of bounds
> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> Cc: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>, "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>
> Yes, write to beagle-support.
> On Aug 20, 2011, at 14:52, "Jonathan Monette" <jonmon at mcs.anl.gov> wrote:
> Ok thanks. It seems that I was not added to the beagle-notify list. Could someone point me to a link I can subscribe to? Or do I subscribe by sending mail to beagle-support?
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> Date: Sat, Aug 20, 2011 7:45 am
> Cc: <swift-devel at ci.uchicago.edu>
> Yes, Beagle went down yesterday. There was a notice.
> Current status as of Aug 19, 5.30PM:
> At this time, Lustre is not starting properly on Beagle.  This may be related to a configuration change that was made during the last outage.  The effort to restore system availability is still in active progress.
> Ketan
> On Sat, Aug 20, 2011 at 12:03 AM, Jonathan Monette <jonmon at mcs.anl.gov> wrote:
> I updated and rebuilt and added that line to my log4j properties.  Does anyone know if Beagle is down?  showq says there is no service listening to sdb:<number>.  qstat shows that I have a job sitting in the queue but it doesn't look like jobs are running.
> I am using both PADS and Beagle for this execution.  In this case where jobs are not executing on Beagle shouldn't Swift start submitting jobs to PADS?  I do not see that behavior.
> This run is still executing.  But if you would like to look at the log it is at www.ci.uchicago.edu/~jonmon/logs/montage-2.log.  Only 23 tasks have finished before it just sits there waiting for Beagle to run.
> On Aug 19, 2011, at 2:46 PM, Jonathan Monette wrote:
> > Sure can. I add that line to the log4j file or in a different properties file.
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > Date: Fri, Aug 19, 2011 2:03 pm
> > Subject: Index out of bounds
> > Hmm. So I can't see how this manages to happen.
> > I added some checks and debugging statements. Can you update, set log
> > level of org.globus.cog.abstraction.impl.file.local to DEBUG, re-run and
> > then post the log when the exception pops up?
> > Mihael
> > On Thu, 2011-08-18 at 23:14 -0500, Jonathan Monette wrote:
> > > Ok.  The log is at
> > > www.ci.uchicago.edu/~jonmon/logs/montage-1.log
> > > On Aug 18, 2011, at 5:56 PM, Mihael Hategan wrote:
> > > > It's probably a good idea to post the stack trace of that exception now
> > > > rather than later.
> > > > On Thu, 2011-08-18 at 13:09 -0500, Jonathan Monette wrote:
> > > >> Hello,
> > > >>  I was running 0.93 with one a relatively small run, a 350 task run.
> > > >> The run failed on one of the final tasks. I checked the log file and
> > > >> saw some index out of bounds errors. I tried with a smaller run and
> > > >> didn't see the error.
> > > >> This run was using beagle, pads, and communicado. I was also using
> > > >> cdm. I will post the log in a bit. I am seeing if I cam replicate it
> > > >> without using cdm and with a smaller site pool.
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110822/e34f3e14/attachment.html>
