[Swift-devel] Blocker issue for 0.93: DSSAT script does not complete, 2nd coaster blocks dont start?
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Mon Aug 22 10:32:31 CDT 2011
Mike,
If I recall correctly, Papia has always been running her DSSAT app with
0.92. She has not yet tried with 0.93. I too tried with 0.92 with her sites
file settings.
I once tried it with 0.93 on pads but could never get in the running from
the queue.
I will give another try today as it might be that PADS was too busy last
week. As I recall Jon was also struggling to get access.
Ketan
On Mon, Aug 22, 2011 at 10:24 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Papia, Ketan,
> In reviewing 0.93 work remaining with David, I remembered this issue.
> You both reported that the DSSAT application script doesnt finish on PADS -
> it seems not to start the second round of coaster blocks that it needs to
> complete (as I recall, but this may not be correct).  This needs to be
> researched and filed as a bug (or, an error in the sites spec needs to be
> identified and made clear in the site guide if it turns out to be the
> problem).
> Possible there is an issue with jobs failing at the end of the coaster
> blocks, and you dont have the necessary retry values set for the PADS
> site???
> We need an example run with logs and full details. Can you try to re-create
> this with a much smaller initial allocation, and see if coasters is
> transitioning from its initial blocks to the next blocks?
> Can you give this high prio for today?
> Thanks,
> - Mike
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110822/ed860600/attachment.html>
