[Swift-devel] Blocker issue for 0.93: DSSAT script does not complete, 2nd coaster blocks dont start?
Michael Wilde
wilde at mcs.anl.gov
Mon Aug 22 10:24:52 CDT 2011
Papia, Ketan,
In reviewing 0.93 work remaining with David, I remembered this issue.
You both reported that the DSSAT application script doesnt finish on PADS - it seems not to start the second round of coaster blocks that it needs to complete (as I recall, but this may not be correct). This needs to be researched and filed as a bug (or, an error in the sites spec needs to be identified and made clear in the site guide if it turns out to be the problem).
Possible there is an issue with jobs failing at the end of the coaster blocks, and you dont have the necessary retry values set for the PADS site???
We need an example run with logs and full details. Can you try to re-create this with a much smaller initial allocation, and see if coasters is transitioning from its initial blocks to the next blocks?
Can you give this high prio for today?
- Mike
