[Swift-devel] Swift 0.93 exception on Fusion
    David Kelly
    davidk at ci.uchicago.edu
    Wed Aug 17 14:53:41 CDT 2011
Thanks Mihael, that fixed it.
David
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: swift-devel at ci.uchicago.edu
> Sent: Wednesday, August 17, 2011 2:47:38 PM
> Subject: Re: [Swift-devel] Swift 0.93 exception on Fusion
> Fixed in svn.
> On Wed, 2011-08-17 at 11:34 -0500, David Kelly wrote:
> > Hello,
> > When testing 0.93 on Fusion, Swift throws an exception. I am running
> > with the catsn script. It runs, creates the output, but then gives
> > this error when cleaning up:
> > Final status: time: Wed, 17 Aug 2011 11:17:38 -0500 Finished
> > successfully:10
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > Cannot submit job
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:67)
> > 	at
> > 	org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> > 	at
> > 	org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
> > 	at
> > 	org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> > Caused by: java.lang.NullPointerException
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.makeName(PBSExecutor.java:304)
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.writeScript(PBSExecutor.java:205)
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.buildCommandLine(AbstractExecutor.java:169)
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:89)
> > 	at
> > 	org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> > 	... 3 more
> > The config and log files are attached. They can also be found on
> > fusion in ~davidk/temp. This is filed in bugzilla as bug #515.
> > David
> > _______________________________________________ Swift-devel mailing
> > list Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
