[Swift-devel] Swift 0.93 exception on Fusion
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Aug 17 14:47:38 CDT 2011
Fixed in svn.
On Wed, 2011-08-17 at 11:34 -0500, David Kelly wrote:
> Hello,
> When testing 0.93 on Fusion, Swift throws an exception. I am running with the catsn script. It runs, creates the output, but then gives this error when cleaning up:
> Final status:  time: Wed, 17 Aug 2011 11:17:38 -0500  Finished successfully:10
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Cannot submit job
> 	at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:67)
> 	at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> 	at org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
> 	at org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> Caused by: java.lang.NullPointerException
> 	at org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.makeName(PBSExecutor.java:304)
> 	at org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.writeScript(PBSExecutor.java:205)
> 	at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.buildCommandLine(AbstractExecutor.java:169)
> 	at org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:89)
> 	at org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> 	... 3 more
> The config and log files are attached. They can also be found on fusion in ~davidk/temp. This is filed in bugzilla as bug #515.
> David
> _______________________________________________ Swift-devel mailing list Swift-devel at ci.uchicago.edu https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
