[Swift-devel] Swift 0.93 exception on Fusion
Michael Wilde
wilde at mcs.anl.gov
Wed Aug 17 11:43:38 CDT 2011
David, one possibility here is that (automatic) coasters is generating an additional job with invalid PBS attributes.
Can you turn on debug=true in etc/pbs.properties and take a look to see if thats the case?
The NPE is an issue in the pbs/localsched provider, but perhaps caused by na unexpected problem or state in the pbs jobs.
- Mike
----- Original Message -----
> From: "David Kelly" <davidk at ci.uchicago.edu>
> To: swift-devel at ci.uchicago.edu
> Sent: Wednesday, August 17, 2011 11:34:06 AM
> Subject: [Swift-devel] Swift 0.93 exception on Fusion
> Hello,
> When testing 0.93 on Fusion, Swift throws an exception. I am running
> with the catsn script. It runs, creates the output, but then gives
> this error when cleaning up:
> Final status: time: Wed, 17 Aug 2011 11:17:38 -0500 Finished
> successfully:10
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Cannot submit job
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:67)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
> Caused by: java.lang.NullPointerException
> at
> org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.makeName(PBSExecutor.java:304)
> at
> org.globus.cog.abstraction.impl.scheduler.pbs.PBSExecutor.writeScript(PBSExecutor.java:205)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.buildCommandLine(AbstractExecutor.java:169)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:89)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> ... 3 more
> The config and log files are attached. They can also be found on
> fusion in ~davidk/temp. This is filed in bugzilla as bug #515.
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
