[Swift-devel] provider staging question
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Aug 16 22:33:14 CDT 2011
Mike,
Here is an old mail snippet (May) that you sent about the scratch tag:
I was surprised to see that coaster provider staging used the
<workdirectory> tag to determine the jobdir on the compute node, on Beagle
where /tmp is not writeable.  I always thought that it would honor the <
scratch> tag to let the user specify the provider staging jobdir.  But this
seems not to be the case.
So, it seems that the scratch tag is not really honored.
On Tue, Aug 16, 2011 at 10:08 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Right, I remember that now, but I cant recall if the scratch tag was
> completely broken, was set incorrectly, was interfering with debugging, or
> was interacting incorrectly with some other setting.
> Papia, if you recall, please clarify.
> Thanks,
> - Mike
> > From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Tuesday, August 16, 2011 9:14:24 PM
> > Subject: Re: provider staging question
> > That is what I was thinking about CDM but wasn't sure if that is what
> > you meant in the email a couple days ago.
> > I thought that the scratch tag was broken from the sites file. I
> > thought it was mentioned before that Papia was experiencing problems
> > when using the scratch tag in her sites file.
> > On Aug 16, 2011, at 8:15 PM, Michael Wilde wrote:
> > > Hi Jon,
> > > I'll try a short answer, but this needs more thoight, and much
> > > testing:
> > > - Dont use CDM with provider staging (yet; maybe someday that will
> > > make sense...)
> > > I dont tthink the two will work together well.
> > > - ps should stage to the local hard disk; I *think* it may honor the
> > > workdirectory tag as where to stage, though. Or maybe the scratch
> > > tag? I think it defaults to /tmp. This needs to be tested and
> > > documented. Mihael, can you clarify?
> > > Miek
> > >> Sent: Tuesday, August 16, 2011 6:08:47 PM
> > >> Subject: provider staging question
> > >> Mike,
> > >> I am configuring the run to test the SwiftMontage runs with
> > >> provider
> > >> staging turned on as you suggested. When I turn on provider staging
> > >> should I not use CDM? The issue that I was experiencing that led me
> > >> to
> > >> start using CDM was extremely long copy times from the cwd to the
> > >> job
> > >> directory specified by the <workdirectory> in the sites.xml file.
> > >> Does
> > >> provider staging circumvent that issue? I know provider staging
> > >> copies
> > >> the input files directly onto the compute nodes local disk but that
> > >> is
> > >> about all I know. Could you fill me in a bit on what exactly
> > >> provider
> > >> staging does? Would using both CDM "direct" directives and provider
> > >> staging cause some degraded performance?
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> Michael Wilde
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110816/87e72af3/attachment.html>
