[Swift-devel] provider staging question
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Aug 16 22:08:22 CDT 2011
Right, I remember that now, but I cant recall if the scratch tag was completely broken, was set incorrectly, was interfering with debugging, or was interacting incorrectly with some other setting.
Papia, if you recall, please clarify.
- Mike
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
> Sent: Tuesday, August 16, 2011 9:14:24 PM
> Subject: Re: provider staging question
> That is what I was thinking about CDM but wasn't sure if that is what
> you meant in the email a couple days ago.
> I thought that the scratch tag was broken from the sites file. I
> thought it was mentioned before that Papia was experiencing problems
> when using the scratch tag in her sites file.
> On Aug 16, 2011, at 8:15 PM, Michael Wilde wrote:
> > Hi Jon,
> > I'll try a short answer, but this needs more thoight, and much
> > testing:
> > - Dont use CDM with provider staging (yet; maybe someday that will
> > make sense...)
> > I dont tthink the two will work together well.
> > - ps should stage to the local hard disk; I *think* it may honor the
> > workdirectory tag as where to stage, though. Or maybe the scratch
> > tag? I think it defaults to /tmp. This needs to be tested and
> > documented. Mihael, can you clarify?
> > Miek
> >> Sent: Tuesday, August 16, 2011 6:08:47 PM
> >> Subject: provider staging question
> >> Mike,
> >> I am configuring the run to test the SwiftMontage runs with
> >> provider
> >> staging turned on as you suggested. When I turn on provider staging
> >> should I not use CDM? The issue that I was experiencing that led me
> >> to
> >> start using CDM was extremely long copy times from the cwd to the
> >> job
> >> directory specified by the <workdirectory> in the sites.xml file.
> >> Does
> >> provider staging circumvent that issue? I know provider staging
> >> copies
> >> the input files directly onto the compute nodes local disk but that
> >> is
> >> about all I know. Could you fill me in a bit on what exactly
> >> provider
> >> staging does? Would using both CDM "direct" directives and provider
> >> staging cause some degraded performance?
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
