[Swift-devel] ssh test case on pads/beagle
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Aug 11 02:18:07 CDT 2011
Can you post (a link to) the entire log file? Since it contains both the
tc.data and sites.xml and the error, it's probably always better to post
than individual snippets.
On Thu, 2011-08-11 at 01:17 -0500, Alberto Chavez wrote:
> Sure:
> <config>
> <pool handle="ssh">
> <execution provider="ssh" url="steamroller" jobmanager="ssh"/>
>  <filesystem provider="ssh" url="steamroller" />
>  <profile key="jobThrottle" namespace="karajan">0</profile>
>  <workdirectory>/home/achavez/swiftwork</workdirectory>
>  </pool>
>  </config>
> ______________________________________________________________________
> To: alberto_chavez at live.com
> From: jonmon at mcs.anl.gov
> CC: hategan at mcs.anl.gov; swift-devel at ci.uchicago.edu
> Subject: Re: [Swift-devel] ssh test case on pads/beagle
> Date: Wed, 10 Aug 2011 23:54:24 -0500
> Could you post the sites file?
> ----- Reply message -----
> From: "Alberto Chavez" <alberto_chavez at live.com>
> Date: Wed, Aug 10, 2011 7:16 pm
> Subject: [Swift-devel] ssh test case on pads/beagle
> To: <jonmon at mcs.anl.gov>
> Cc: "Mihael Hategan" <hategan at mcs.anl.gov>, "Swift Devel"
> <swift-devel at ci.uchicago.edu>
> Exit code "127" normally means that a particular function doesn't
> exist.  Are you sure that all those paths to apps exist?
> > Yes, I doubled check that and those are the right paths to the apps.
> Also, I am not sure if this is a problem but shouldn't there be a
> third column in the app file?  LIke
> "ssh echo /bin/echo null null null"
> Looking at the documentation for the transformation catalog, the
> structure should be:
> site, transformation name, executable path, installation status,
> platform, and profile entries.
> The installation status and platform fields are not used. Set them
> to INSTALLED and INTEL32::LINUX respectively.
> The profiles field should be set to null if no profile entries are to
> be specified, or should contain the profile entries separated by
> semicolons.
> but even when I switch the columns to INSTALLED and INTEL32::LINUX and
> keep the profiles field set to null, I'm still getting the same exit
> code.
> On Aug 10, 2011, at 6:41 PM, Alberto Chavez wrote:
>         I changed my ssh-key, and they worked on the MCS machines
>         because the authorized_keys file has not been updated yet on
>         the CI Machines.
>         I created a new ssh-key using:
>         ssh-keygen -t rsa -b 2048
>         exactly as the MCS site suggested,
>         On the other hand, I still have a problem, I am getting the
>         following error:
>         Swift svn swift-r4978 cog-r3226
>         RunID: 20110810-1819-1cdo2o62
>         Progress:  time: Wed, 10 Aug 2011 18:19:42 -0500
>         Exception in cat:
>         Arguments: [data.txt]
>         Host: ssh
>         Directory:
>         001-catsn-ssh-20110810-1819-1cdo2o62/jobs/9/cat-9jd0g9ek
>         Caused by: null
>         Caused by:
>         org.globus.cog.abstraction.impl.common.execution.JobException:
>         Job failed with an exit code of 127
>         Final status:  time: Wed, 10 Aug 2011 18:20:00 -0500
>          Failed:10
>         The following errors have occurred:
>         1. Job failed with an exit code of 127 (10 times)
>         These are the contents of the log:
>         Execution completed with errors
>         2011-08-10 18:19:43,251-0500 INFO  ConnectionProtocol Freeing
>         channel 0 [Unnamed Channel]
>         2011-08-10 18:19:43,263-0500 INFO  Exec Exit code 127
>         2011-08-10 18:19:43,269-0500 INFO  ConnectionProtocol Freeing
>         2011-08-10 18:19:43,277-0500 DEBUG vdl:execute2
>         APPLICATION_EXCEPTION jobid=cat-9jd0g9ek - Application
>         exception: null
>         Caused by:
>         2011-08-10 18:19:43,280-0500 INFO  vdl:execute END_FAILURE
>         thread=0-5-3-1 tr=cat
>         2011-08-10 18:19:43,281-0500 INFO  vdl:execute Exception in
>         cat:
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:250)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:254)
>                 at
>         org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:27)
>                 at
>         org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>                 at
>         org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
>                 at
>         org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>                 at
>         org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>                 at
>         org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>                 at
>         org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
>                 at
>         org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>                 at
>         org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>                 at java.util.concurrent.Executors
>         $RunnableAdapter.call(Executors.java:471)
>                 at java.util.concurrent.FutureTask
>         $Sync.innerRun(FutureTask.java:334)
>                 at
>         java.util.concurrent.FutureTask.run(FutureTask.java:166)
>                 at
>         java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
>                 at java.util.concurrent.ThreadPoolExecutor
>         $Worker.run(ThreadPoolExecutor.java:603)
>                 at java.lang.Thread.run(Thread.java:636)
>         2011-08-10 18:20:00,332-0500 INFO  ExecutionContext Detailed
>         exception:
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>                 at
>         I believe that the problem resides on the TC file because when
>         I run a much simpler SwiftScript like:
>                 int i = 9;
>                 trace(i);
>         I get the following output:
>                 swift traceme.swift -tc.file tc.template.data
>                 -sites.file sites.template.xml -config cf
>                 RunID: 20110810-1832-buktjj3d
>                 Progress:  time: Wed, 10 Aug 2011 18:32:30 -0500
>                 SwiftScript trace: 9.0
>                 Final status:  time: Wed, 10 Aug  2011 18:32:30 -0500
>         but as soon as I start using the commands stated the TC file,
>         I get the "exit code 127"
>         My tc file reads:
>                 ssh     cat             /bin/cat        null    null
>                 ssh     ls              /bin/ls         null    null
>                 ssh     grep            /bin/grep       null    null
>                 ssh     sort            /bin/sort       null    null
>                 ssh     paste           /bin/paste      null    null
>                 ssh     wc              /usr/bin/wc     null    null
>         I am working on the login node of the MCS machine trying to
>         ssh via Swift to steamroller.
>         > From: hategan at mcs.anl.gov
>         > CC: swift-devel at ci.uchicago.edu
>         > Date: Tue, 9 Aug 2011 11:57:06 -0700
>         > Hmm: Unsupported passphrase algorithm: AES-128-CBC
>         > I'll try to see how that can be fixed. In the mean time, can
>         you
>         > generate a new key pair with 3DES encryption instead and use
>         that?
>         > On Tue, 2011-08-09 at 13:43 -0500, Alberto Chavez wrote:
>         > > Hello,
>         > > I am trying to run a simpler case than ssh-pbs-coaster
>         test case, and
>         > > I'm still having the same error.
>         > > Now I am running only ssh test case
>         > > (/tests/providers/ssh/001-catsn-ssn.swift)
>         > > The command line is:
>         > > swift -config cf -tc.file tc.template.data -sites.file
>         > > sites.template.xml 001-catsn-ssh.swift
>         > > The output:
>         > > Swift svn swift-r4861 (swift modified locally) cog-r3183
>         > > RunID: 20110809-1336-ohte788a
>         > > Progress: time: Tue, 09 Aug 2011 13:36:42 -0500
>         > > Exception in cat:
>         > > Host: ssh
>         > > Directory:
>         001-catsn-ssh-20110809-1336-ohte788a/jobs/m/cat-mq74h7ek
>         > > Caused by: null
>         > > Caused by:
>         org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphrase
>         > > Caused by:
>         com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException:
>         Can't
>         > > read key due to cryptography problems:
>         > > java.security.NoSuchAlgorithmException: Unsupported
>         passphrase
>         > > Progress: time: Tue, 09 Aug 2011 13:36:43 -0500 Selecting
>         site:8
>         > > Submitting:1 Failed:1
>         > > Exception in cat:
>         > > Host: ssh
>         > > Directory:
>         001-catsn-ssh-20110809-1336-ohte788a/jobs/n/cat-nq74h7ek
>         > > Caused by: null
>         > > Caused by:
>         > > Caused by:
>         Can't
>         passphrase
>         > > Progress: time: Tue, 09 Aug 2011 13:36:44 -0500 Selecting
>         site:7
>         > > Submitting:1 Failed:2
>         > > Exception in cat:
>         > > Host: ssh
>         > > Directory:
>         001-catsn-ssh-20110809-1336-ohte788a/jobs/o/cat-oq74h7ek
>         > > Caused by: null
>         > > Caused by:
>         > > Caused by:
>         Can't
>         passphrase
>         > > "error_log.log" 105L, 5770C
>         > > My auth.defaults reads:
>         > > login1.beagle.ci.uchicago.edu.type=key
>         > > login1.beagle.ci.uchicago.edu.username=achavez
>         login1.beagle.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
>         > > login1.pads.ci.uchicago.edu.type=key
>         > > login1.pads.ci.uchicago.edu.username=achavez
>         login1.pads.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
>         > > and it has been set to 600, I ommited the passphrase line,
>         but it is
>         > > there, and the passphrase is right because I just verified
>         it in two
>         > > ways:
>         > > 1) by logging to pads and beagle without providing a
>         password
>         > > 2) "changed" the password. I the "new" password is the
>         same as the
>         > > "old" one.
>         > > sites.templates.xml:
>         > > <config>
>         > > <pool handle="ssh">
>         url="login1.pads.ci.uchicago.edu"
>         > > jobmanager="ssh"/>
>         url="login1.pads.ci.uchicago.edu" />
>         > > </pool>
>         > > </config>
>         > > config file:
>         > > wrapperlog.always.transfer=true
>         > > sitedir.keep=true
>         > > execution.retries=0
>         > > lazy.errors=true
>         > > status.mode=provider
>         > > use.provider.staging=true
>         > > provider.staging.pin.swiftfiles=false
>         > > foreach.max.threads=10
>         > > provenance.log=true
>         > > I also tried a simpler SwiftScript:
>         > > type filemsg;
>         > > app (filemsg output) hello(string s)
>         > > echo s stdout=@filename(output);
>         > > filemsg myfile<"dogcatdinosaur.out">;
>         > > myfile = hello("dog,cat,dinosaur");
>         > > and I get the following output:
>         > > RunID: 20110809-1343-2es2hel2
>         > > Progress: time: Tue, 09 Aug 2011 13:43:25 -0500
>         > > Exception in echo:
>         > > Arguments: [dog,cat,dinosaur]
>         > > Host: ssh
>         > > Directory:
>         hello_swift-20110809-1343-2es2hel2/jobs/0/echo-0oldh7ek
>         > > Caused by: null
>         > > Caused by:
>         > > Caused by:
>         Can't
>         passphrase
>         > > Final status: time: Tue, 09 Aug 2011 13:43:26 -0500
>         Failed:1
>         > > 1. Can't read key due to cryptography problems:
>         passphrase
>         > > any thoughts on this?
>         > > Swift-devel mailing list
>         > > Swift-devel at ci.uchicago.edu
>         > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
