[Swift-devel] ssh test case on pads/beagle
    Alberto Chavez
    alberto_chavez at live.com
    Thu Aug 11 01:17:40 CDT 2011
Sure:
<config><pool handle="ssh"><execution provider="ssh" url="steamroller" jobmanager="ssh"/> <filesystem provider="ssh" url="steamroller" /> <profile key="jobThrottle" namespace="karajan">0</profile> <workdirectory>/home/achavez/swiftwork</workdirectory> </pool> </config>
To: alberto_chavez at live.com
CC: hategan at mcs.anl.gov; swift-devel at ci.uchicago.edu
Subject: Re: [Swift-devel] ssh test case on pads/beagle
Date: Wed, 10 Aug 2011 23:54:24 -0500
Could you post the sites file?
----- Reply message -----
From: "Alberto Chavez" <alberto_chavez at live.com>
Date: Wed, Aug 10, 2011 7:16 pm
Subject: [Swift-devel] ssh test case on pads/beagle
To: <jonmon at mcs.anl.gov>
Cc: "Mihael Hategan" <hategan at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
Exit code "127" normally means that a particular function doesn't exist.  Are you sure that all those paths to apps exist?> Yes, I doubled check that and those are the right paths to the apps.
Also, I am not sure if this is a problem but shouldn't there be a third column in the app file?  LIke"ssh		echo	/bin/echo	null		null		null"
Looking at the documentation for the transformation catalog, the structure should be:
site, transformation name, executable path, installation status, platform, and profile entries.
The installation status and platform fields are not used. Set them to INSTALLED and INTEL32::LINUX respectively.The profiles field should be set to null if no profile entries are to be specified, or should contain the profile entries separated by semicolons.
but even when I switch the columns to INSTALLED and INTEL32::LINUX and keep the profiles field set to null, I'm still getting the same exit code.On Aug 10, 2011, at 6:41 PM, Alberto Chavez wrote:I changed my ssh-key, and they worked on the MCS machines because the authorized_keys file has not been updated yet on the CI Machines. I created a new ssh-key using:ssh-keygen -t rsa -b 2048exactly as the MCS site suggested,On the other hand, I still have a problem, I am getting the following error:
Swift svn swift-r4978 cog-r3226
RunID: 20110810-1819-1cdo2o62Progress:  time: Wed, 10 Aug 2011 18:19:42 -0500Exception in cat:Arguments: [data.txt]Host: sshDirectory: 001-catsn-ssh-20110810-1819-1cdo2o62/jobs/9/cat-9jd0g9ek- - -Caused by: nullCaused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 127Final status:  time: Wed, 10 Aug 2011 18:20:00 -0500  Failed:10The following errors have occurred:1. Job failed with an exit code of 127 (10 times)
These are the contents of the log:
Execution completed with errors
2011-08-10 18:19:43,251-0500 INFO  ConnectionProtocol Freeing channel 0 [Unnamed Channel]2011-08-10 18:19:43,263-0500 INFO  Exec Exit code 1272011-08-10 18:19:43,269-0500 INFO  ConnectionProtocol Freeing channel 0 [Unnamed Channel]2011-08-10 18:19:43,277-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION jobid=cat-9jd0g9ek - Application exception: nullCaused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 1272011-08-10 18:19:43,280-0500 INFO  vdl:execute END_FAILURE thread=0-5-3-1 tr=cat2011-08-10 18:19:43,281-0500 INFO  vdl:execute Exception in cat:        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:250)        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:254)        at org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:27)        at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)        at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)        at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)        at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)        at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)        at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)        at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)        at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)        at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)        at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)        at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)        at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)        at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)        at java.util.concurrent.FutureTask.run(FutureTask.java:166)        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)        at java.lang.Thread.run(Thread.java:636)2011-08-10 18:20:00,332-0500 INFO  ExecutionContext Detailed exception:
        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:250)        at org.globus.cog.karajan.workflow.nodes.FlowNode.fail(FlowNode.java:254)        at org.globus.cog.karajan.workflow.nodes.GenerateErrorNode.post(GenerateErrorNode.java:27)        at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)        at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)        at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)        at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)        at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)        at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)        at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)        at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)        at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)        at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)        at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)        at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)        at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)        at java.util.concurrent.FutureTask.run(FutureTask.java:166)        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)        at java.lang.Thread.run(Thread.java:636)I believe that the problem resides on the TC file because when I run a much simpler SwiftScript like:int i = 9;trace(i);I get the following output:swift traceme.swift -tc.file tc.template.data -sites.file sites.template.xml -config cf Swift svn swift-r4978 cog-r3226RunID: 20110810-1832-buktjj3dProgress:  time: Wed, 10 Aug 2011 18:32:30 -0500SwiftScript trace: 9.0Final status:  time: Wed, 10 Aug  2011 18:32:30 -0500but as soon as I start using the commands stated the TC file, I get the "exit code 127"My tc file reads:ssh     echo            /bin/echo       null    nullssh     cat             /bin/cat        null    nullssh     ls              /bin/ls         null    nullssh     grep            /bin/grep       null    nullssh     sort            /bin/sort       null    nullssh     paste           /bin/paste      null    nullssh     wc              /usr/bin/wc     null    nullI am working on the login node of the MCS machine trying to ssh via Swift to steamroller.
> From: hategan at mcs.anl.gov
> CC: swift-devel at ci.uchicago.edu
> Date: Tue, 9 Aug 2011 11:57:06 -0700
> Hmm: Unsupported passphrase algorithm: AES-128-CBC
> I'll try to see how that can be fixed. In the mean time, can you
> generate a new key pair with 3DES encryption instead and use that?
> On Tue, 2011-08-09 at 13:43 -0500, Alberto Chavez wrote:
> > Hello,
> > I am trying to run a simpler case than ssh-pbs-coaster test case, and
> > I'm still having the same error.
> > Now I am running only ssh test case
> > (/tests/providers/ssh/001-catsn-ssn.swift)
> > The command line is:
> > swift -config cf -tc.file tc.template.data -sites.file
> > sites.template.xml 001-catsn-ssh.swift
> > The output:
> > Swift svn swift-r4861 (swift modified locally) cog-r3183
> > RunID: 20110809-1336-ohte788a
> > Progress: time: Tue, 09 Aug 2011 13:36:42 -0500
> > Exception in cat:
> > Host: ssh
> > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/m/cat-mq74h7ek
> > Caused by: null
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException: Invalid private key or passphrase
> > Caused by:
> > com.sshtools.j2ssh.transport.publickey.InvalidSshKeyException: Can't
> > read key due to cryptography problems:
> > java.security.NoSuchAlgorithmException: Unsupported passphrase
> > Progress: time: Tue, 09 Aug 2011 13:36:43 -0500 Selecting site:8
> > Submitting:1 Failed:1
> > Exception in cat:
> > Host: ssh
> > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/n/cat-nq74h7ek
> > Caused by: null
> > Caused by:
> > Caused by:
> > Progress: time: Tue, 09 Aug 2011 13:36:44 -0500 Selecting site:7
> > Submitting:1 Failed:2
> > Exception in cat:
> > Host: ssh
> > Directory: 001-catsn-ssh-20110809-1336-ohte788a/jobs/o/cat-oq74h7ek
> > Caused by: null
> > Caused by:
> > Caused by:
> > "error_log.log" 105L, 5770C
> > My auth.defaults reads:
> > login1.beagle.ci.uchicago.edu.type=key
> > login1.beagle.ci.uchicago.edu.username=achavez
> > login1.beagle.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
> > login1.pads.ci.uchicago.edu.type=key
> > login1.pads.ci.uchicago.edu.username=achavez
> > login1.pads.ci.uchicago.edu.key=/home/Alberto/.ssh/identity
> > and it has been set to 600, I ommited the passphrase line, but it is
> > there, and the passphrase is right because I just verified it in two
> > ways:
> > 1) by logging to pads and beagle without providing a password
> > 2) "changed" the password. I the "new" password is the same as the
> > "old" one.
> > sites.templates.xml:
> > <config>
> > <pool handle="ssh">
> > <execution provider="ssh" url="login1.pads.ci.uchicago.edu"
> > jobmanager="ssh"/>
> > <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" />
> > </pool>
> > </config>
> > config file:
> > wrapperlog.always.transfer=true
> > sitedir.keep=true
> > execution.retries=0
> > lazy.errors=true
> > status.mode=provider
> > use.provider.staging=true
> > provider.staging.pin.swiftfiles=false
> > foreach.max.threads=10
> > provenance.log=true
> > I also tried a simpler SwiftScript:
> > type filemsg;
> > app (filemsg output) hello(string s)
> > echo s stdout=@filename(output);
> > filemsg myfile<"dogcatdinosaur.out">;
> > myfile = hello("dog,cat,dinosaur");
> > and I get the following output:
> > RunID: 20110809-1343-2es2hel2
> > Progress: time: Tue, 09 Aug 2011 13:43:25 -0500
> > Exception in echo:
> > Arguments: [dog,cat,dinosaur]
> > Host: ssh
> > Directory: hello_swift-20110809-1343-2es2hel2/jobs/0/echo-0oldh7ek
> > Caused by: null
> > Caused by:
> > Caused by:
> > Final status: time: Tue, 09 Aug 2011 13:43:26 -0500 Failed:1
> > 1. Can't read key due to cryptography problems:
> > any thoughts on this?
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110811/4a8e0383/attachment.html>
