[Swift-devel] trunk coasters
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Aug  4 23:22:31 CDT 2011
Im still getting the errors below (which I think are what I reported prior to this fix).  I'll double check that I got the latest fix in, but I think I do.
- Mike
2011-08-04 23:17:47,757-0500 DEBUG Cpu workerStarted: swork:node016:0
2011-08-04 23:17:47,757-0500 DEBUG Cpu swork:0 pullLater
2011-08-04 23:17:47,758-0500 INFO  Block Started CPU 0:1312517867s
2011-08-04 23:17:47,758-0500 INFO  Block Started worker swork:000000
2011-08-04 23:17:47,758-0500 INFO  Cpu swork:0 pull
2011-08-04 23:17:47,761-0500 WARN  BlockQueueProcessor Failed to send worker status update to client
java.lang.NullPointerException
        at org.globus.cog.karajan.workflow.service.channels.ChannelManager.getMetaChannel(ChannelManager.java:433)
        at org.globus.cog.karajan.workflow.service.channels.ChannelManager.reserveChannel(ChannelManager.java:226)
        at org.globus.cog.abstraction.coaster.service.job.manager.PassiveQueueProcessor.registrationReceived(PassiveQueueProcessor.java:72)
        at org.globus.cog.abstraction.coaster.service.job.manager.JobQueue.registrationReceived(JobQueue.java:143)
        at org.globus.cog.abstraction.coaster.service.LocalTCPService.registrationReceived(LocalTCPService.java:64)
        at org.globus.cog.abstraction.coaster.service.local.RegistrationHandler.requestComplete(RegistrationHandler.java:57)
        at org.globus.cog.karajan.workflow.service.handlers.RequestHandler.receiveCompleted(RequestHandler.java:84)
        at org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel.handleRequest(AbstractKarajanChannel.java:416)
        at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel.step(AbstractStreamKarajanChannel.java:157)
        at org.globus.cog.karajan.workflow.service.channels.AbstractStreamKarajanChannel$Multiplexer.run(AbstractStreamKarajanChannel.java:375)
2011-08-04 23:17:47,764-0500 INFO  LocalTCPService Received registration: blockid = swork, url = node016
2011-08-04 23:17:47,765-0500 INFO  AbstractKarajanChannel MetaChannel: 467772424[15735326: {}] -> null: Disabling heartbeats (config is null)
2011-08-04 23:17:47,765-0500 INFO  MetaChannel MetaChannel: 467772424[15735326: {}] -> null.bind -> SC-null
2011-08-04 23:17:47,765-0500 DEBUG Cpu workerStarted: swork:node016:1
2011-08-04 23:17:47,765-0500 DEBUG Cpu swork:1 pullLater
2011-08-04 23:17:47,765-0500 INFO  Block Started CPU 1:1312517867s
2011-08-04 23:17:47,765-0500 INFO  Cpu swork:1 pull
2011-08-04 23:17:47,765-0500 INFO  Block Started worker swork:000001
2011-08-04 23:17:47,766-0500 WARN  BlockQueueProcessor Failed to send worker status update to client
2011-08-04 23:17:48,568-0500 INFO  TCPBufferManager Adjusting buffer size to 524288
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Justin M Wozniak" <wozniak at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, August 4, 2011 6:09:56 PM
> Subject: Re: [Swift-devel] trunk coasters
> On Thu, 2011-08-04 at 15:29 -0500, Michael Wilde wrote:
> > So the other error - the failing service - is not happing on local
> > tests on 0.93; next I'll try the remote cases.
> Ok. I committed a number of things to trunk, one of which is a fix for
> the messed up channel lookup problem.
> I used it previously for auto-deployed services on ranger and pads,
> but
> haven't tried it with the stand-alone service. So please test that if
> you can and let me know.
> I'll now move to dealing with 0.93 issues.
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
