[Swift-devel] ssh:pbs to beagle
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Apr 28 15:00:04 CDT 2011
The EOFException persists.
However, on bridled-communicado I get this one:
[ketan at bridled catsn.works]$ swift -config cf -tc.file tc -sites.file coaster-local-ssh-communicado.xml catsn.swift -n=1
Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified locally)
RunID: 20110428-1457-r7bzx1ha
Progress:
Progress:  Active:1
Exception in cat:
Arguments: [data.txt]
Host: communicado-ssh
Directory: catsn-20110428-1457-r7bzx1ha/jobs/t/cat-tlf05d9kTODO: outs
Caused by: Job failed with an exit code of 524
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 524
Final status:  Failed:1
The following errors have occurred:
1. Job failed with an exit code of 524
Any clue what could it be due to?
Ketan
On Apr 28, 2011, at 2:49 PM, Michael Wilde wrote:
> Copying these might work for you, Ketan:
> com$ env | grep 509
> X509_CERT_DIR=/home/wilde/TRUSTEDCA
> X509_CADIR=/home/wilde/TRUSTEDCA
> com$
>> You have a bunch of uknown CA errors in there.
>> You should have the CA public key for your proxy in
>> ~/.globus/certificates (on both client and server machines).
>> Mihael
>> On Thu, 2011-04-28 at 14:29 -0500, Ketan Maheshwari wrote:
>>> They are here : /home/ketan/.globus/coasters
>>> On Apr 28, 2011, at 2:26 PM, Mihael Hategan wrote:
>>>> That EOFException doesn't make much sense.
>>>> On beagle you should have something called coaster.log in
>>>> ~/.globus/coasters.
>>>> Can post a link to that?
>>>> Mihael
>>>> On Thu, 2011-04-28 at 14:21 -0500, Ketan Maheshwari wrote:
>>>>> On Apr 28, 2011, at 2:17 PM, Mihael Hategan wrote:
>>>>>> What does your sites file look like?
>>>>> ** For beagle **
>>>>> <config>
>>>>>   <!--<pool handle="pbs">-->
>>>>> <pool handle="beagle-remote-pbs-coasters-ssh">
>>>>>   <execution provider="coaster"
>>>>>   url="login1.beagle.ci.uchicago.edu" jobmanager="ssh:pbs"/>
>>>>>   <profile namespace="globus"
>>>>>   key="project">CI-CCR000013</profile>
>>>>>   <profile namespace="globus" key="ppn">24:cray:pack</profile>
>>>>>   <profile namespace="globus" key="workersPerNode">24</profile>
>>>>>   <profile namespace="globus" key="maxTime">1000</profile>
>>>>>   <profile namespace="globus" key="slots">1</profile>
>>>>>   <profile namespace="globus" key="nodeGranularity">1</profile>
>>>>>   <profile namespace="globus" key="maxNodes">1</profile>
>>>>>   <profile namespace="karajan" key="jobThrottle">.63</profile>
>>>>>   key="initialScore">10000</profile>
>>>>>   <filesystem provider="ssh" url="login1.beagle.ci.uchicago.edu"
>>>>>   <workdirectory>$HOME/swift.workdir</workdirectory>
>>>>> </pool>
>>>>> </config>
>>>>> ** for communicado **
>>>>> <config>
>>>>> <pool handle="communicado-ssh">
>>>>>   url="communicado.ci.uchicago.edu" jobmanager="ssh:ssh"/>
>>>>>   <filesystem provider="ssh" url="communicado.ci.uchicago.edu"
>>>>> </pool>
>>>>> </config>
>>>>>> On Thu, 2011-04-28 at 13:36 -0500, Ketan Maheshwari wrote:
>>>>>>> Ok, I got past CredentialException with grid-proxy-init, now I
>>>>>>> am facing this (note: I have turned on provider staging) :
>>>>>>> -sites.file beagle-coaster-ssh-pbs.xml catsn.swift -n=1
>>>>>>> modified locally)
>>>>>>> RunID: 20110428-1332-llaa031f
>>>>>>> Progress:
>>>>>>> Could not start connection handler
>>>>>>> java.io.EOFException
>>>>>>> 	at
>>>>>>> 	org.globus.gsi.gssapi.net.impl.GSIGssInputStream.readHandshakeToken(GSIGssInputStream.java:61)
>>>>>>> 	at
>>>>>>> 	org.globus.gsi.gssapi.net.impl.GSIGssSocket.readToken(GSIGssSocket.java:65)
>>>>>>> 	at
>>>>>>> 	org.globus.gsi.gssapi.net.GssSocket.authenticateServer(GssSocket.java:127)
>>>>>>> 	at
>>>>>>> 	org.globus.gsi.gssapi.net.GssSocket.startHandshake(GssSocket.java:147)
>>>>>>> 	at
>>>>>>> 	org.globus.gsi.gssapi.net.GssSocket.getInputStream(GssSocket.java:177)
>>>>>>> 	at
>>>>>>> 	org.globus.cog.karajan.workflow.service.channels.AbstractTCPChannel.setSocket(AbstractTCPChannel.java:30)
>>>>>>> 	at
>>>>>>> 	org.globus.cog.karajan.workflow.service.channels.GSSChannel.<init>(GSSChannel.java:47)
>>>>>>> 	at
>>>>>>> 	org.globus.cog.karajan.workflow.service.ConnectionHandler.<init>(ConnectionHandler.java:41)
>>>>>>> 	at
>>>>>>> 	org.globus.cog.abstraction.coaster.service.local.LocalService.handleConnection(LocalService.java:63)
>>>>>>> 	at org.globus.net.BaseServer.run(BaseServer.java:247)
>>>>>>> 	at java.lang.Thread.run(Thread.java:662)
>>>>>>> Progress: Submitted:1
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> 	at
>>>>>>> Exception in cat:
>>>>>>> Host: beagle-remote-pbs-coasters-ssh
>>>>>>> Directory:
>>>>>>> catsn-20110428-1332-llaa031f/jobs/b/cat-bxal1d9kTODO: outs
>>>>>>> Caused by: Could not submit job
>>>>>>> Caused by:
>>>>>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>>>>>>> Caused by:
>>>>>>> Could not start coaster service
>>>>>>> Caused by:
>>>>>>> Task ended before registration was received.
>>>>>>> STDOUT:
>>>>>>> STDERR:
>>>>>>> Caused by:
>>>>>>> Job failed with an exit code of 1
>>>>>>> 1. Job failed with an exit code of 1
>>>>>>> From bridled to communicado, I see the following error:
>>>>>>> modified locally)
>>>>>>> RunID: 20110428-1335-k685b2ye
>>>>>>> Progress:
>>>>>>> Progress: Active:1
>>>>>>> Exception in cat:
>>>>>>> Directory:
>>>>>>> catsn-20110428-1335-k685b2ye/jobs/c/cat-coip1d9kTODO: outs
>>>>>>> Caused by:
>>>>>>> Ketan
>>>>>>> On Apr 28, 2011, at 1:03 PM, Michael Wilde wrote:
>>>>>>>> For now - create a proxy using grid-proxy-init on the swift
>>>>>>>> execution machine.
>>>>>>>> I think there is an option to set "no security" for this
>>>>>>>> config but I cant recall where that is specified. Maybe
>>>>>>>> swift.properties, I cant recall.
>>>>>>>> - Mike
>>>>>>>>> Hi,
>>>>>>>>> It looks better now. However, I am getting the following:
>>>>>>>>> -sites.file
>>>>>>>>> modified
>>>>>>>>> locally)
>>>>>>>>> RunID: 20110428-1251-oi9theh8
>>>>>>>>> Progress:
>>>>>>>>> Progress: Stage in:1
>>>>>>>>> Caused by:
>>>>>>>>> Caused by:
>>>>>>>>> Caused by:
>>>>>>>>> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
>>>>>>>>> org.globus.gsi.GlobusCredentialException: [JGLOBUS-5] Proxy
>>>>>>>>> file
>>>>>>>>> (/tmp/x509up_u2006) not found.
>>>>>>>>> Caused by: org.globus.gsi.GlobusCredentialException:
>>>>>>>>> [JGLOBUS-5] Proxy
>>>>>>>>> file (/tmp/x509up_u2006) not found.
>>>>>>>>> Failed to transfer wrapper log from
>>>>>>>>> catsn-20110428-1251-oi9theh8/info/e on
>>>>>>>>> How do I specify "-nosec" on automatic coasters?
>>>>>>>>> Ketan
>>>>>>>>> On Apr 28, 2011, at 12:00 PM, Michael Wilde wrote:
>>>>>>>>>> OK. Was there a cookbook on the ssh settings? Did you set up
>>>>>>>>>> a
>>>>>>>>>> $HOME/.ssh/auth.defaults per the user guide?
>>>>>>>>>> Here is an auth.defaults example. Im not sure its 100%
>>>>>>>>>> correct, but
>>>>>>>>>> could serve as a base for you:
>>>>>>>>>> xlogin1.pads.ci.uchicago.edu.type=password
>>>>>>>>>> xlogin1.pads.ci.uchicago.edu.username=wilde
>>>>>>>>>> login.pads.ci.uchicago.edu.type=key
>>>>>>>>>> login.pads.ci.uchicago.edu.username=wilde
>>>>>>>>>> login.pads.ci.uchicago.edu.key=/home/wilde/.ssh/swift_rsa
>>>>>>>>>> login.pads.ci.uchicago.edu.passphrase=yourpassphrasehere #
>>>>>>>>>> MAKE SURE
>>>>>>>>>> mode=600!!!
>>>>>>>>>> login1.pads.ci.uchicago.edu.type=key
>>>>>>>>>> login1.pads.ci.uchicago.edu.key=/home/wilde/.ssh/swift_rsa
>>>>>>>>>> login1.pads.ci.uchicago.edu.passphrase=yourpassphrasehere #
>>>>>>>>>> MAKE
>>>>>>>>>> SURE mode=600!!!
>>>>>>>>>> login.mcs.anl.gov.type=key
>>>>>>>>>> login.mcs.anl.gov.username=wilde
>>>>>>>>>> login.mcs.anl.gov.key=/home/wilde/.ssh/swift_rsa
>>>>>>>>>> login.mcs.anl.gov.passphrase=yourpassphrasehere # MAKE SURE
>>>>>>>>>> mode=600!!!
>>>>>>>>>> - Mike
>>>>>>>>>>> It does look like an ssh problem. I am getting the same
>>>>>>>>>>> stderr and
>>>>>>>>>>> log
>>>>>>>>>>> messages on trying to communicate from Bridled to
>>>>>>>>>>> Communicado.
>>>>>>>>>>> Ketan
>>>>>>>>>>> On Apr 28, 2011, at 11:19 AM, Michael Wilde wrote:
>>>>>>>>>>>> Have you already run a simple hellow-world swift test from
>>>>>>>>>>>> communicado to bridled to make sure you have ssh
>>>>>>>>>>>> configured
>>>>>>>>>>>> correctly? I would do that first.
>>>>>>>>>>>> Im not sure if an ssh problem explains what you show
>>>>>>>>>>>> below, or
>>>>>>>>>>>> not.
>>>>>>>>>>>> - Mike
>>>>>>>>>>>>> Thanks, I made the change. However, now, I am getting the
>>>>>>>>>>>>> following
>>>>>>>>>>>>> on
>>>>>>>>>>>>> my stderr
>>>>>>>>>>>>> -sites.file
>>>>>>>>>>>>> (cog
>>>>>>>>>>>>> modified
>>>>>>>>>>>>> locally)
>>>>>>>>>>>>> RunID: 20110428-1022-n9s0k0e0
>>>>>>>>>>>>> Progress:
>>>>>>>>>>>>> [ketan]
>>>>>>>>>>>>> Progress: Initializing site shared directory:1
>>>>>>>>>>>>> [ketan] Progress: Initializing site shared directory:1
>>>>>>>>>>>>> And from the log it seems some network transmission has
>>>>>>>>>>>>> failed:
>>>>>>>>>>>>> 2011-04-28 10:22:45,261-0500 INFO TransportProtocolCommon
>>>>>>>>>>>>> Sending
>>>>>>>>>>>>> SSH_MSG_SERVICE_REQUEST
>>>>>>>>>>>>> 2011-04-28 10:22:45,264-0500 INFO TransportProtocolCommon
>>>>>>>>>>>>> Received
>>>>>>>>>>>>> SSH_MSG_SERVICE_ACCEPT
>>>>>>>>>>>>> 2011-04-28 10:24:27,626-0500 INFO TransportProtocolCommon
>>>>>>>>>>>>> The
>>>>>>>>>>>>> Transport Protocol thread failed
>>>>>>>>>>>>> java.io.IOException: The socket is EOF
>>>>>>>>>>>>> at
>>>>>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readBufferedData(TransportProtocolInputStream.java:183)
>>>>>>>>>>>>> at
>>>>>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readMessage(TransportProtocolInputStream.java:226)
>>>>>>>>>>>>> at
>>>>>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.processMessages(TransportProtocolCommon.java:1440)
>>>>>>>>>>>>> at
>>>>>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.startBinaryPacketProtocol(TransportProtocolCommon.java:1034)
>>>>>>>>>>>>> at
>>>>>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.run(TransportProtocolCommon.java:393)
>>>>>>>>>>>>> Any clues?
>>>>>>>>>>>>> Ketan
>>>>>>>>>>>>> On Apr 28, 2011, at 10:20 AM, Michael Wilde wrote:
>>>>>>>>>>>>>> The pool name in your sites file is
>>>>>>>>>>>>>> pads-remote-pbs-coasters-ssh
>>>>>>>>>>>>>> but
>>>>>>>>>>>>>> you used pbs in your tc.data.
>>>>>>>>>>>>>> - Mike
>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>> Some context:
>>>>>>>>>>>>>>> I am trying to submit a big run on Beagle using swift +
>>>>>>>>>>>>>>> coasters.
>>>>>>>>>>>>>>> However, a previous run is already underway on beagle.
>>>>>>>>>>>>>>> So,
>>>>>>>>>>>>>>> there
>>>>>>>>>>>>>>> are
>>>>>>>>>>>>>>> two difficulties running a new run from its login node:
>>>>>>>>>>>>>>> 1. Running another swift from the same jvm will result
>>>>>>>>>>>>>>> in chaos
>>>>>>>>>>>>>>> on
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> logs (As far as I know, please correct me if this is
>>>>>>>>>>>>>>> not the
>>>>>>>>>>>>>>> case
>>>>>>>>>>>>>>> anymore)
>>>>>>>>>>>>>>> 2. Login node is already under load because of my
>>>>>>>>>>>>>>> running
>>>>>>>>>>>>>>> previous
>>>>>>>>>>>>>>> big
>>>>>>>>>>>>>>> run.
>>>>>>>>>>>>>>> /context
>>>>>>>>>>>>>>> So, I am now trying to submit this big run from a
>>>>>>>>>>>>>>> remote host
>>>>>>>>>>>>>>> (bridled). I know this has been done on PADS using
>>>>>>>>>>>>>>> ssh:pbs,
>>>>>>>>>>>>>>> provider
>>>>>>>>>>>>>>> coaster. I tried the similar approach on a trial swift
>>>>>>>>>>>>>>> script
>>>>>>>>>>>>>>> but
>>>>>>>>>>>>>>> getting error.
>>>>>>>>>>>>>>> Following is the error message:
>>>>>>>>>>>>>>> tc
>>>>>>>>>>>>>>> -sites.file
>>>>>>>>>>>>>>> cog-r3088 (cog
>>>>>>>>>>>>>>> modified
>>>>>>>>>>>>>>> locally)
>>>>>>>>>>>>>>> RunID: 20110428-1002-c8rvqhe6
>>>>>>>>>>>>>>> Progress:
>>>>>>>>>>>>>>> The application "cat" is not available in your tc.data
>>>>>>>>>>>>>>> catalog
>>>>>>>>>>>>>>> Caused by:
>>>>>>>>>>>>>>> org.globus.cog.karajan.scheduler.NoSuchResourceException
>>>>>>>>>>>>>>> 1. The application "cat" is not available in your
>>>>>>>>>>>>>>> tc.data
>>>>>>>>>>>>>>> catalog
>>>>>>>>>>>>>>> Attached are my .swift, sites.xml and tc.data files.
>>>>>>>>>>>>>>> Could someone indicate if what I am doing is doable and
>>>>>>>>>>>>>>> if so
>>>>>>>>>>>>>>> how
>>>>>>>>>>>>>>> can
>>>>>>>>>>>>>>> I correctly configure my sites and tc setup.
>>>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>>>> Ketan
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>>>>>>>>>>>>>> Michael Wilde
>>>>>>>>>>>>>> Computation Institute, University of Chicago
>>>>>>>>>>>>>> Mathematics and Computer Science Division
>>>>>>>>>>>>>> Argonne National Laboratory
>>>>>>>>>>>> Michael Wilde
>>>>>>>>>> Michael Wilde
>>>>>>>> Michael Wilde
> Michael Wilde
