[Swift-devel] ssh:pbs to beagle
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 28 14:49:52 CDT 2011
Copying these might work for you, Ketan:
com$ env | grep 509
X509_CERT_DIR=/home/wilde/TRUSTEDCA
X509_CADIR=/home/wilde/TRUSTEDCA
com$
----- Original Message -----
> You have a bunch of uknown CA errors in there.
> You should have the CA public key for your proxy in
> ~/.globus/certificates (on both client and server machines).
> Mihael
> On Thu, 2011-04-28 at 14:29 -0500, Ketan Maheshwari wrote:
> > They are here : /home/ketan/.globus/coasters
> > On Apr 28, 2011, at 2:26 PM, Mihael Hategan wrote:
> > > That EOFException doesn't make much sense.
> > > On beagle you should have something called coaster.log in
> > > ~/.globus/coasters.
> > > Can post a link to that?
> > > Mihael
> > > On Thu, 2011-04-28 at 14:21 -0500, Ketan Maheshwari wrote:
> > >> On Apr 28, 2011, at 2:17 PM, Mihael Hategan wrote:
> > >>> What does your sites file look like?
> > >> ** For beagle **
> > >> <config>
> > >>    <!--<pool handle="pbs">-->
> > >>  <pool handle="beagle-remote-pbs-coasters-ssh">
> > >>    <execution provider="coaster"
> > >>    url="login1.beagle.ci.uchicago.edu" jobmanager="ssh:pbs"/>
> > >>    <profile namespace="globus"
> > >>    key="project">CI-CCR000013</profile>
> > >>    <profile namespace="globus" key="ppn">24:cray:pack</profile>
> > >>    <profile namespace="globus" key="workersPerNode">24</profile>
> > >>    <profile namespace="globus" key="maxTime">1000</profile>
> > >>    <profile namespace="globus" key="slots">1</profile>
> > >>    <profile namespace="globus" key="nodeGranularity">1</profile>
> > >>    <profile namespace="globus" key="maxNodes">1</profile>
> > >>    <profile namespace="karajan" key="jobThrottle">.63</profile>
> > >>    key="initialScore">10000</profile>
> > >>    <filesystem provider="ssh" url="login1.beagle.ci.uchicago.edu"
> > >>    <workdirectory>$HOME/swift.workdir</workdirectory>
> > >>  </pool>
> > >> </config>
> > >> ** for communicado **
> > >> <config>
> > >>  <pool handle="communicado-ssh">
> > >>    url="communicado.ci.uchicago.edu" jobmanager="ssh:ssh"/>
> > >>    <filesystem provider="ssh" url="communicado.ci.uchicago.edu"
> > >>  </pool>
> > >> </config>
> > >>> On Thu, 2011-04-28 at 13:36 -0500, Ketan Maheshwari wrote:
> > >>>> Ok, I got past CredentialException with grid-proxy-init, now I
> > >>>> am facing this (note: I have turned on provider staging) :
> > >>>> [ketan at bridled catsn.works]$ swift -config cf -tc.file tc
> > >>>> -sites.file beagle-coaster-ssh-pbs.xml catsn.swift -n=1
> > >>>> Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog
> > >>>> modified locally)
> > >>>> RunID: 20110428-1332-llaa031f
> > >>>> Progress:
> > >>>> Could not start connection handler
> > >>>> java.io.EOFException
> > >>>> 	at
> > >>>> 	org.globus.gsi.gssapi.net.impl.GSIGssInputStream.readHandshakeToken(GSIGssInputStream.java:61)
> > >>>> 	at
> > >>>> 	org.globus.gsi.gssapi.net.impl.GSIGssSocket.readToken(GSIGssSocket.java:65)
> > >>>> 	at
> > >>>> 	org.globus.gsi.gssapi.net.GssSocket.authenticateServer(GssSocket.java:127)
> > >>>> 	at
> > >>>> 	org.globus.gsi.gssapi.net.GssSocket.startHandshake(GssSocket.java:147)
> > >>>> 	at
> > >>>> 	org.globus.gsi.gssapi.net.GssSocket.getInputStream(GssSocket.java:177)
> > >>>> 	at
> > >>>> 	org.globus.cog.karajan.workflow.service.channels.AbstractTCPChannel.setSocket(AbstractTCPChannel.java:30)
> > >>>> 	at
> > >>>> 	org.globus.cog.karajan.workflow.service.channels.GSSChannel.<init>(GSSChannel.java:47)
> > >>>> 	at
> > >>>> 	org.globus.cog.karajan.workflow.service.ConnectionHandler.<init>(ConnectionHandler.java:41)
> > >>>> 	at
> > >>>> 	org.globus.cog.abstraction.coaster.service.local.LocalService.handleConnection(LocalService.java:63)
> > >>>> 	at org.globus.net.BaseServer.run(BaseServer.java:247)
> > >>>> 	at java.lang.Thread.run(Thread.java:662)
> > >>>> Progress: Submitted:1
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> 	at
> > >>>> Exception in cat:
> > >>>> Arguments: [data.txt]
> > >>>> Host: beagle-remote-pbs-coasters-ssh
> > >>>> Directory:
> > >>>> catsn-20110428-1332-llaa031f/jobs/b/cat-bxal1d9kTODO: outs
> > >>>> Caused by: Could not submit job
> > >>>> Caused by:
> > >>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > >>>> Caused by:
> > >>>> Could not start coaster service
> > >>>> Caused by:
> > >>>> Task ended before registration was received.
> > >>>> STDOUT:
> > >>>> STDERR:
> > >>>> Caused by:
> > >>>> org.globus.cog.abstraction.impl.common.execution.JobException:
> > >>>> Job failed with an exit code of 1
> > >>>> Final status: Failed:1
> > >>>> The following errors have occurred:
> > >>>> 1. Job failed with an exit code of 1
> > >>>> From bridled to communicado, I see the following error:
> > >>>> -sites.file coaster-local-ssh-communicado.xml catsn.swift -n=1
> > >>>> modified locally)
> > >>>> RunID: 20110428-1335-k685b2ye
> > >>>> Progress:
> > >>>> Progress: Active:1
> > >>>> Exception in cat:
> > >>>> Host: communicado-ssh
> > >>>> Directory:
> > >>>> catsn-20110428-1335-k685b2ye/jobs/c/cat-coip1d9kTODO: outs
> > >>>> Caused by: Job failed with an exit code of 524
> > >>>> Caused by:
> > >>>> 1. Job failed with an exit code of 524
> > >>>> Ketan
> > >>>> On Apr 28, 2011, at 1:03 PM, Michael Wilde wrote:
> > >>>>> For now - create a proxy using grid-proxy-init on the swift
> > >>>>> execution machine.
> > >>>>> I think there is an option to set "no security" for this
> > >>>>> config but I cant recall where that is specified. Maybe
> > >>>>> swift.properties, I cant recall.
> > >>>>> - Mike
> > >>>>>> Hi,
> > >>>>>> It looks better now. However, I am getting the following:
> > >>>>>> -sites.file
> > >>>>>> modified
> > >>>>>> locally)
> > >>>>>> RunID: 20110428-1251-oi9theh8
> > >>>>>> Progress:
> > >>>>>> Progress: Stage in:1
> > >>>>>> Caused by:
> > >>>>>> Caused by:
> > >>>>>> Caused by:
> > >>>>>> org.globus.cog.abstraction.impl.common.task.InvalidSecurityContextException:
> > >>>>>> org.globus.gsi.GlobusCredentialException: [JGLOBUS-5] Proxy
> > >>>>>> file
> > >>>>>> (/tmp/x509up_u2006) not found.
> > >>>>>> Caused by: org.globus.gsi.GlobusCredentialException:
> > >>>>>> [JGLOBUS-5] Proxy
> > >>>>>> file (/tmp/x509up_u2006) not found.
> > >>>>>> Failed to transfer wrapper log from
> > >>>>>> catsn-20110428-1251-oi9theh8/info/e on
> > >>>>>> How do I specify "-nosec" on automatic coasters?
> > >>>>>> Ketan
> > >>>>>> On Apr 28, 2011, at 12:00 PM, Michael Wilde wrote:
> > >>>>>>> OK. Was there a cookbook on the ssh settings? Did you set up
> > >>>>>>> a
> > >>>>>>> $HOME/.ssh/auth.defaults per the user guide?
> > >>>>>>> Here is an auth.defaults example. Im not sure its 100%
> > >>>>>>> correct, but
> > >>>>>>> could serve as a base for you:
> > >>>>>>> xlogin1.pads.ci.uchicago.edu.type=password
> > >>>>>>> xlogin1.pads.ci.uchicago.edu.username=wilde
> > >>>>>>> login.pads.ci.uchicago.edu.type=key
> > >>>>>>> login.pads.ci.uchicago.edu.username=wilde
> > >>>>>>> login.pads.ci.uchicago.edu.key=/home/wilde/.ssh/swift_rsa
> > >>>>>>> login.pads.ci.uchicago.edu.passphrase=yourpassphrasehere #
> > >>>>>>> MAKE SURE
> > >>>>>>> mode=600!!!
> > >>>>>>> login1.pads.ci.uchicago.edu.type=key
> > >>>>>>> login1.pads.ci.uchicago.edu.key=/home/wilde/.ssh/swift_rsa
> > >>>>>>> login1.pads.ci.uchicago.edu.passphrase=yourpassphrasehere #
> > >>>>>>> MAKE
> > >>>>>>> SURE mode=600!!!
> > >>>>>>> login.mcs.anl.gov.type=key
> > >>>>>>> login.mcs.anl.gov.username=wilde
> > >>>>>>> login.mcs.anl.gov.key=/home/wilde/.ssh/swift_rsa
> > >>>>>>> login.mcs.anl.gov.passphrase=yourpassphrasehere # MAKE SURE
> > >>>>>>> mode=600!!!
> > >>>>>>> - Mike
> > >>>>>>>> It does look like an ssh problem. I am getting the same
> > >>>>>>>> stderr and
> > >>>>>>>> log
> > >>>>>>>> messages on trying to communicate from Bridled to
> > >>>>>>>> Communicado.
> > >>>>>>>> Ketan
> > >>>>>>>> On Apr 28, 2011, at 11:19 AM, Michael Wilde wrote:
> > >>>>>>>>> Have you already run a simple hellow-world swift test from
> > >>>>>>>>> communicado to bridled to make sure you have ssh
> > >>>>>>>>> configured
> > >>>>>>>>> correctly? I would do that first.
> > >>>>>>>>> Im not sure if an ssh problem explains what you show
> > >>>>>>>>> below, or
> > >>>>>>>>> not.
> > >>>>>>>>> - Mike
> > >>>>>>>>>> Thanks, I made the change. However, now, I am getting the
> > >>>>>>>>>> following
> > >>>>>>>>>> on
> > >>>>>>>>>> my stderr
> > >>>>>>>>>> -sites.file
> > >>>>>>>>>> (cog
> > >>>>>>>>>> modified
> > >>>>>>>>>> locally)
> > >>>>>>>>>> RunID: 20110428-1022-n9s0k0e0
> > >>>>>>>>>> Progress:
> > >>>>>>>>>> [ketan]
> > >>>>>>>>>> Progress: Initializing site shared directory:1
> > >>>>>>>>>> [ketan] Progress: Initializing site shared directory:1
> > >>>>>>>>>> And from the log it seems some network transmission has
> > >>>>>>>>>> failed:
> > >>>>>>>>>> 2011-04-28 10:22:45,261-0500 INFO TransportProtocolCommon
> > >>>>>>>>>> Sending
> > >>>>>>>>>> SSH_MSG_SERVICE_REQUEST
> > >>>>>>>>>> 2011-04-28 10:22:45,264-0500 INFO TransportProtocolCommon
> > >>>>>>>>>> Received
> > >>>>>>>>>> SSH_MSG_SERVICE_ACCEPT
> > >>>>>>>>>> 2011-04-28 10:24:27,626-0500 INFO TransportProtocolCommon
> > >>>>>>>>>> The
> > >>>>>>>>>> Transport Protocol thread failed
> > >>>>>>>>>> java.io.IOException: The socket is EOF
> > >>>>>>>>>> at
> > >>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readBufferedData(TransportProtocolInputStream.java:183)
> > >>>>>>>>>> at
> > >>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolInputStream.readMessage(TransportProtocolInputStream.java:226)
> > >>>>>>>>>> at
> > >>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.processMessages(TransportProtocolCommon.java:1440)
> > >>>>>>>>>> at
> > >>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.startBinaryPacketProtocol(TransportProtocolCommon.java:1034)
> > >>>>>>>>>> at
> > >>>>>>>>>> com.sshtools.j2ssh.transport.TransportProtocolCommon.run(TransportProtocolCommon.java:393)
> > >>>>>>>>>> Any clues?
> > >>>>>>>>>> Ketan
> > >>>>>>>>>> On Apr 28, 2011, at 10:20 AM, Michael Wilde wrote:
> > >>>>>>>>>>> The pool name in your sites file is
> > >>>>>>>>>>> pads-remote-pbs-coasters-ssh
> > >>>>>>>>>>> but
> > >>>>>>>>>>> you used pbs in your tc.data.
> > >>>>>>>>>>> - Mike
> > >>>>>>>>>>>> Hello,
> > >>>>>>>>>>>> Some context:
> > >>>>>>>>>>>> I am trying to submit a big run on Beagle using swift +
> > >>>>>>>>>>>> coasters.
> > >>>>>>>>>>>> However, a previous run is already underway on beagle.
> > >>>>>>>>>>>> So,
> > >>>>>>>>>>>> there
> > >>>>>>>>>>>> are
> > >>>>>>>>>>>> two difficulties running a new run from its login node:
> > >>>>>>>>>>>> 1. Running another swift from the same jvm will result
> > >>>>>>>>>>>> in chaos
> > >>>>>>>>>>>> on
> > >>>>>>>>>>>> the
> > >>>>>>>>>>>> logs (As far as I know, please correct me if this is
> > >>>>>>>>>>>> not the
> > >>>>>>>>>>>> case
> > >>>>>>>>>>>> anymore)
> > >>>>>>>>>>>> 2. Login node is already under load because of my
> > >>>>>>>>>>>> running
> > >>>>>>>>>>>> previous
> > >>>>>>>>>>>> big
> > >>>>>>>>>>>> run.
> > >>>>>>>>>>>> /context
> > >>>>>>>>>>>> So, I am now trying to submit this big run from a
> > >>>>>>>>>>>> remote host
> > >>>>>>>>>>>> (bridled). I know this has been done on PADS using
> > >>>>>>>>>>>> ssh:pbs,
> > >>>>>>>>>>>> provider
> > >>>>>>>>>>>> coaster. I tried the similar approach on a trial swift
> > >>>>>>>>>>>> script
> > >>>>>>>>>>>> but
> > >>>>>>>>>>>> getting error.
> > >>>>>>>>>>>> Following is the error message:
> > >>>>>>>>>>>> tc
> > >>>>>>>>>>>> -sites.file
> > >>>>>>>>>>>> cog-r3088 (cog
> > >>>>>>>>>>>> modified
> > >>>>>>>>>>>> locally)
> > >>>>>>>>>>>> RunID: 20110428-1002-c8rvqhe6
> > >>>>>>>>>>>> Progress:
> > >>>>>>>>>>>> The application "cat" is not available in your tc.data
> > >>>>>>>>>>>> catalog
> > >>>>>>>>>>>> Caused by:
> > >>>>>>>>>>>> org.globus.cog.karajan.scheduler.NoSuchResourceException
> > >>>>>>>>>>>> 1. The application "cat" is not available in your
> > >>>>>>>>>>>> tc.data
> > >>>>>>>>>>>> catalog
> > >>>>>>>>>>>> Attached are my .swift, sites.xml and tc.data files.
> > >>>>>>>>>>>> Could someone indicate if what I am doing is doable and
> > >>>>>>>>>>>> if so
> > >>>>>>>>>>>> how
> > >>>>>>>>>>>> can
> > >>>>>>>>>>>> I correctly configure my sites and tc setup.
> > >>>>>>>>>>>> Thanks.
> > >>>>>>>>>>>> Ketan
> > >>>>>>>>>>>> _______________________________________________
> > >>>>>>>>>>>> Swift-devel mailing list
> > >>>>>>>>>>>> Swift-devel at ci.uchicago.edu
> > >>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > >>>>>>>>>>> Michael Wilde
> > >>>>>>>>>>> Computation Institute, University of Chicago
> > >>>>>>>>>>> Mathematics and Computer Science Division
> > >>>>>>>>>>> Argonne National Laboratory
> > >>>>>>>>> Michael Wilde
> > >>>>>>> Michael Wilde
> > >>>>> Michael Wilde
Michael Wilde
