[Swift-devel] Website documentation
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Sat Apr 23 12:00:07 CDT 2011
Yeah- I am trying to be more careful with umask.  Please send me your
error message and I will modify the chmods in the script accordingly.
For the new structure, I recommend that we stop using svn to move the
content and just push the simple documents.  I would be fine with a
cp-based method that only works from a CI system.
On Sat, 23 Apr 2011, Michael Wilde wrote:
> Looking deeper into this, I see that the permissions in /ci
> /www/projects/swift do not permit anyone in vdl2-svn to do svn-update
> and to run update.sh completely for the entire doc set.
> Justin, I think this occurred when you last worked on this directory.
> Can you see if update.sh works for you at the moment? That should push
> David's committed tutorial corrections to the live content.
> I suggest that rather than correct this, we push ahead updating the
> entire per-release doc set to asciidoc and then adjust update.sh and the
> /ci/www/projects/swift directory to match it. David, can you do this
> under bug 375, and propose the new structure with a README that outlines
> how all the directories and content-push scripts will be organized?
> Thanks,
> Mike
> David, you're not in the vdl2-svn UNIX group, which you need in order to run this. I'll request that you be added, and do an svn-co of the tutorial and run update.sh for you in the meantime.
> - Mike
> Hello,
> What is the current process for updating website documentation? I believe the MaintainingSwiftWebContent wiki may be out of date.
> I am trying to submit some corrections to the Swift tutorial. Previously I could modify it through www/ in SVN. Now I believe it is generated from swift/docs/tutorial.xml for each release. Is this correct? Is there still a cron job that runs daily and updates the site? I am not seeing the changes I made yesterday reflected on the website. Do I need to manually run /ci/www/projects/swift/update.sh? I do not have permissions to read or execute it at the moment.
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Justin M Wozniak
