[Swift-devel] Website documentation
    Michael Wilde
    wilde at mcs.anl.gov
    Sat Apr 23 09:14:49 CDT 2011
Looking deeper into this, I see that the permissions in /ci /www/projects/swift do not permit anyone in vdl2-svn to do svn-update and to run update.sh completely for the entire doc set.
Justin, I think this occurred when you last worked on this directory. Can you see if update.sh works for you at the moment? That should push David's committed tutorial corrections to the live content.
I suggest that rather than correct this, we push ahead updating the entire per-release doc set to asciidoc and then adjust update.sh and the /ci/www/projects/swift directory to match it. David, can you do this under bug 375, and propose the new structure with a README that outlines how all the directories and content-push scripts will be organized?
Mike
----- Original Message -----
David, you're not in the vdl2-svn UNIX group, which you need in order to run this. I'll request that you be added, and do an svn-co of the tutorial and run update.sh for you in the meantime.
- Mike
Hello,
What is the current process for updating website documentation? I believe the MaintainingSwiftWebContent wiki may be out of date.
I am trying to submit some corrections to the Swift tutorial. Previously I could modify it through www/ in SVN. Now I believe it is generated from swift/docs/tutorial.xml for each release. Is this correct? Is there still a cron job that runs daily and updates the site? I am not seeing the changes I made yesterday reflected on the website. Do I need to manually run /ci/www/projects/swift/update.sh? I do not have permissions to read or execute it at the moment.
David
Swift-devel mailing list
Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110423/8f8cd354/attachment.html>
