[Swift-devel] Re: [Swift-commit] r4363 - branches
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Apr 13 15:13:45 CDT 2011
On Wed, 2011-04-13 at 12:35 -0700, Sarah Kenny wrote:
> they should get it directly from tags instead of svn co
> https://svn.ci.uchicago.edu/svn/vdl2/branches/release-0.92 swift ?
Yes. That's because the branch may change. If we discover another big
bug we may have 0.92.2.
> On Wed, Apr 13, 2011 at 12:14 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         On Wed, 2011-04-13 at 12:09 -0700, Sarah Kenny wrote:
>         > alrighty, so, does this seem right to everyone?
>         Almost. The instructions for checking out the source code are
>         not quite
>         right.
>         > http://www.ci.uchicago.edu/~skenny/swift/downloads/index.php
>         > i'm doing a run thru of the site tester now building from
>         > tags/release-0.92.1 as a sanity test and assuming all goes
>         well that's
>         > what i will use to build the binary.
>         > let me know if this sounds ok or if i'm missing anything
>         here.
>         > On Wed, Apr 13, 2011 at 11:53 AM, Mihael Hategan
>         > wrote:
>         >         On Wed, 2011-04-13 at 11:33 -0700, Sarah Kenny
>         wrote:
>         >         > and should the binary then still be called 0.92
>         rather than
>         >         0.92.1 ?
>         >         The binary would be called 0.92.1.
>         >         > being that 0.92 had such a substantial flaw and a
>         warning
>         >         was posted
>         >         > on the site, it seems to me that we'd want to make
>         it clear
>         >         (to users)
>         >         > that this is a new version/release by naming it
>         >         0.92.1...does tagging
>         >         > adequately solve this?
>         >         Tagging doesn't solve that. Tagging is there so that
>         we can
>         >         have some
>         >         label in SVN that matches the packages that we
>         release as
>         >         opposed to
>         >         having to track a specific revision in the branch.
