[Swift-devel] Swift 0.92(.1) on Fusion
David Kelly dk0966 at cs.ship.edu
Wed Apr 13 11:21:49 CDT 2011
The problem is related to the walltime of 00:00:00. The shared queue
that I am trying to use requires a walltime of less than one hour.
Running 'checkjob' reveals that there is a policy violation related to
this.
As a test, I edited the PBS submit file. I set the walltime to a
reasonable value and had it echo something. When I manually submitted
it with qsub, it ran right away.
How can I get a walltime value to be created in the PBS files? I have
maxtime specified in sites.xml and I have a maxwalltime for all my
applications. I tried this with the 0.92 branch as well with trunk
with no luck. Switching to the batch queue might be one workaround.
David
On Wed, Apr 13, 2011 at 10:11 AM, Justin M Wozniak <wozniak at mcs.anl.gov> wrote:
> Thanks for digging into this- can you try this again from trunk?  A Parvis
> developer and I were able to run successfully there.  (The queues are very
> long.)
> One thing I did when working on Fusion was cut out the generated submit
> files and qsub them myself to verify that the #PBS settings did actually
> work for me, you may want to try that too.
>        Justin
> On Wed, 13 Apr 2011, David Kelly wrote:
>> Hello,
>> Recently when I try to run Swift on Fusion, my job never seems to
>> execute. I have emailed Fusion support about this (ticket #70175) but
>> thought it may also be useful to send to the list. I am trying to run
>> the catsn.swift script for testing. I can see it in qstat. The
>> sites.xml is based on the config listed in the Fusion cookbook, with a
>> few small changes. I added an internalHostname entry and set it to the
>> IP address attached to the Infiniband device. I also lowered the
>> maxtime from 1000 to 10. The Fusion cookbook says "Set MAXTIME as in
>> qsub walltime. This is on a per-allocation basis and should be at
>> least 20% larger than your longest task". I am not sure how maxtime
>> relates to walltime exactly, but the walltime value in the PBS file
>> gets set to 00:00:00. I am not sure if this matters or not.
>> I have also attached a compressed log file and the actual swift script
>> I'm trying to run.
>> Thanks,
>> David
>> $ swift -version
>> Swift svn swift-r4076 cog-r3049
>> qstat:
>> 541724.fmgt2.l davidk   shared   Block-0412    --    1    1    --  00:00 Q
>> sites.xml:
>> <config>
>> <pool handle="fusion">
>>  <execution jobmanager="local:pbs" provider="coaster" url="none"/>
>>  <filesystem provider="local" url="none" />
>>  <profile namespace="globus"
>> key="internalHostname">192.168.71.81</profile>
>>  <profile namespace="globus" key="maxtime">10</profile>
>>  <profile namespace="globus" key="workersPerNode">1</profile>
>>  <profile namespace="globus" key="slots">1</profile>
>>  <profile namespace="globus" key="nodeGranularity">1</profile>
>>  <profile namespace="globus" key="maxNodes">2</profile>
>>  <profile namespace="globus" key="queue">shared</profile>
>>  <profile namespace="karajan" key="jobThrottle">5.99</profile>
>>  <profile namespace="karajan" key="initialScore">10000</profile>
>>  <workdirectory>/home/davidk/swiftwork</workdirectory>
>> </pool>
>> </config>
>> PBS submission file:
>> #PBS -S /bin/bash
>> #PBS -N Block-0412-211041-000000
>> #PBS -m n
>> #PBS -l nodes=1
>> #PBS -l walltime=00:00:00
>> #PBS -q shared
>> #PBS -o /homes/davidk/.globus/scripts/PBS1298937999826083605.submit.stdout
>> #PBS -e /homes/davidk/.globus/scripts/PBS1298937999826083605.submit.stderr
>> WORKER_LOGGING_LEVEL=NONE
>> #PBS -v WORKER_LOGGING_LEVEL
>> cd / && /usr/bin/perl
>> /homes/davidk/.globus/coasters/cscript1716491648595514240.pl
>> http://192.168.71.81:46584 0412-211041-000000 NOLOGGING
>> /bin/echo $?
>> >/homes/davidk/.globus/scripts/PBS1298937999826083605.submit.exitcode
> Justin M Wozniak
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110413/dee63f04/attachment.obj>
