[Swift-devel] CCA-11 Swift Poster Visitor's  Questions
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Wed Apr 13 00:00:38 CDT 2011
Here is a list of questions asked by the visitors of our swift poster at the CCA-11 poster session [poster attached here] earlier this evening:
-- What is the novelty in this stuff? Meta-scheduling has been done in the past; scalability studies have also been done in the past (by Swift too).
-- Is this similar to map/reduce?
-- Are you planning to compare Swift/coasters with map/reduce?
-- What do people do without Swift in this same scenario (multi-clouds)?
-- This looks similar to Condor glide-ins!?
-- (After explaining the coasters mechanism) What is sites script again? (some more explaining that it is not script it is a descriptor) And again what is that sites file?
-- What happens without Coasters?
-- What do I need to run Swift on my cluster?
-- Would it benefit me if I chuck Python and use Swift instead for my GIS related app?
-- The simplicity of script-code seems deceptive!?!
-- Is the coasters scheduling algorithm published somewhere?
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110413/53b05748/attachment.pdf>
--Ketan
