[Swift-devel] CCA-11 Swift Poster Visitor's  Questions
    Ian Foster
    foster at anl.gov
    Wed Apr 13 05:30:41 CDT 2011
Hi Ketan:
Nice work transcribing the questions!
I'm curious as to what the "deceptive" question means. The simplicity doesn''t seem deceptive to me!
The poster title is a bit deceptive: it makes this sound like a research poster, when the content reads more like a Swift advertisement. It would be good to produce a paper that provides a detailed description of the coaster's mechanism, a comparison with other work in this area, and a careful evaluation of the functioning of the coaster implementation.
Ian.
On Apr 13, 2011, at 12:00 AM, Ketan Maheshwari wrote:
> Here is a list of questions asked by the visitors of our swift poster at the CCA-11 poster session [poster attached here] earlier this evening:
> -- What is the novelty in this stuff? Meta-scheduling has been done in the past; scalability studies have also been done in the past (by Swift too).
> -- Is this similar to map/reduce?
> -- Are you planning to compare Swift/coasters with map/reduce?
> -- What do people do without Swift in this same scenario (multi-clouds)?
> -- This looks similar to Condor glide-ins!?
> -- (After explaining the coasters mechanism) What is sites script again? (some more explaining that it is not script it is a descriptor) And again what is that sites file?
> -- What happens without Coasters?
> -- What do I need to run Swift on my cluster?
> -- Would it benefit me if I chuck Python and use Swift instead for my GIS related app?
> -- The simplicity of script-code seems deceptive!?!
> -- Is the coasters scheduling algorithm published somewhere?
> <SwiftPoster.CCA-11.pdf>
> --Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
