[Swift-devel] exit code 254,	manual passive coasters on bionimbus cloud
    Ketan Maheshwari
    ketan at mcs.anl.gov
    Mon Apr 11 12:59:11 CDT 2011
That does make sense Jon:
From my experiments, it seems the provider staging is not able to stage-in the app executable. I came to this conclusion because:
1.  The same setup that I am using works for another example where the app is a pre-installed /bin/cat
2. The wrapper log file indeed complains the executable /provided/exe/path does not exist
While I look into more detail on this, could someone confirm if you have used provider staging and faced this issue?
Ketan
On Apr 9, 2011, at 11:28 AM, Jonathan Monette wrote:
> Error 254 means that an app could not execute. Reasons for this are normally tc entry for the app is wrong, the script was not set to executable, staging couldn't be done, or simply the app is not compiled to run on the machine. Does this help in anyway? I am not sure why the TODO: outs is there as I have never seen this line appear in logs or anything.
> On Apr 8, 2011 10:57 PM, "Ketan Maheshwari" <ketan at mcs.anl.gov> wrote:
> > Hi,
> > I am trying the modftdock application on the Bionimbus cloud with the following manual coasters setup:
> > - A Manual coaster service is running on a cloud head node:
> > coaster-service -nosec
> > Local contacts: [http://10.101.13.200:53513, http://10.101.12.200:53513, http://10.101.9.200:53513, http://10.101.11.200:53513, http://10.101.10.200:53513, http://10.101.8.200:53513, http://10.101.7.200:53513, http://10.101.6.200:53513, http://10.101.5.200:53513, http://172.31.0.36:53513, http://131.193.181.210:53513]
> > Started local service: http://131.193.181.210:53513
> > Started coaster service: http://131.193.181.210:1984
> > - Swift on the same above mentioned cloud head node
> > Here is my commandline:
> > swift -config cf -tc.file tc -sites.file bionimbus-coaster-with-provider-staging.xml ftdock.swift -n=1 -list=pdb.list.1 -grid=10
> > worker.pl is running on one VM accessible via ssh
> > Swift Provider staging enabled as staging has to be done from a non-shared filesystem.
> > -- I tested a simple catsn example on this setup and it works so the setup seems fine.
> > However on running the modftdock I get the following 254 message:
> > Swift svn swift-r4157 cog-r3056
> > RunID: 20110408-2235-en2fi70c
> > Progress:
> > SwiftScript trace: 3bg0-1
> > Find: http://localhost:1984
> > Find: keepalive(120), reconnect - http://localhost:1984
> > Progress: Active:1
> > Exception in modftdock:
> > Arguments: [32, -modulo, 0:100, -root, 3bg0-1, -static, input/3bg0-1.pdb, -mobile, input/4TRA.pdb, -calculate_grid, 10, -angle_step, 10, -keep, 10, -noelec]
> > Host: localhost
> > Directory: ftdock-20110408-2235-en2fi70c/jobs/i/modftdock-idyrqf8kTODO: outs
> > Caused by: Job failed with an exit code of 254
> > Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 254
> > Final status: Failed:1
> > The following errors have occurred:
> > 1. Job failed with an exit code of 254
> > I did some find + grep and
> > ** I found the string "TODO: outs" on my SWIFT_HOME/libexec/vdl-int-staging.k
> > In addition, I noticed that workdirectory was not created in my directory.
> > Attached are the cf, tc, bionimbus...xml files
> > Also attached is the log for this run.
> > Thanks for any clues on this.
> > Regards,
> > Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110411/f8619909/attachment.html>
