[Swift-devel] duplicated job submission in swift-0.92?
    Jonathan Monette
    jon.monette at gmail.com
    Sun Apr  3 23:29:21 CDT 2011
Ok.  I will give it a try
On Sun, Apr 3, 2011 at 11:28 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Its in the 0.92 SVN source branches (of both CoG and Swift).  Once we test
> and tag it, it will get released as 0.92.1
> - Mike
> > Sure. Is it all in 0.92 or is it some branch like 0.92.1?
> > On Sun, Apr 3, 2011 at 11:21 PM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > Ive tried the failing examples on a fresh checkout of the 0.92 branch,
> > and that works now - excellent.
> > Allan and Jon, can you try your scripts on this latest 0.92 from svn?
> > Ive also re-built the 0.92 version with Cray support. That seems to
> > work as well.
> > When I updated my 0.92 branch I jumped to: swift-r4252, cog-r3088,
> > which I assume is largely from un-doing the inadvertent post-0.92
> > merge from trunk?
> > - Mike
> > > That would be a tag and we'd do it after we test the current code in
> > > the
> > > branch a bit.
> > > On Sun, 2011-04-03 at 13:16 -0500, Michael Wilde wrote:
> > > > Nice - thank you, Mihael! Can you make the branch next? Call it
> > > > 0.92.1 or .2, whatever you think is best practice (I favor 0.92.1
> > > > but have no strong feeling).
> > > > - Mike
> > > > > On Thu, 2011-03-31 at 11:52 -0700, Mihael Hategan wrote:
> > > > > > We decided the following:
> > > > > > - I will revert the changes in the 0.92 branch
> > > > > done
> > > > > > - re-commit bug fixes that were committed after the merge
> > > > > done
> > > > > > - merge the 0.92 branch to trunk
> > > > > done
> > > > > > - fix the problems in trunk
> > > > > and done except the problem was in the branch. I think it was a
> > > > > manual
> > > > > merge of mine gone wrong. Trunk should be clean.
> > > > > We should make a patch release.
> > > > > Mihael
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
> Michael Wilde
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110403/a592906f/attachment.html>
