[Swift-devel] duplicated job submission in swift-0.92?
    Michael Wilde
    wilde at mcs.anl.gov
    Sun Apr  3 23:28:46 CDT 2011
Its in the 0.92 SVN source branches (of both CoG and Swift).  Once we test and tag it, it will get released as 0.92.1
- Mike
----- Original Message -----
> Sure. Is it all in 0.92 or is it some branch like 0.92.1?
> On Sun, Apr 3, 2011 at 11:21 PM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Ive tried the failing examples on a fresh checkout of the 0.92 branch,
> and that works now - excellent.
> Allan and Jon, can you try your scripts on this latest 0.92 from svn?
> Ive also re-built the 0.92 version with Cray support. That seems to
> work as well.
> When I updated my 0.92 branch I jumped to: swift-r4252, cog-r3088,
> which I assume is largely from un-doing the inadvertent post-0.92
> merge from trunk?
> - Mike
> > That would be a tag and we'd do it after we test the current code in
> > the
> > branch a bit.
> > On Sun, 2011-04-03 at 13:16 -0500, Michael Wilde wrote:
> > > Nice - thank you, Mihael! Can you make the branch next? Call it
> > > 0.92.1 or .2, whatever you think is best practice (I favor 0.92.1
> > > but have no strong feeling).
> > > - Mike
> > > > On Thu, 2011-03-31 at 11:52 -0700, Mihael Hategan wrote:
> > > > > We decided the following:
> > > > > - I will revert the changes in the 0.92 branch
> > > > done
> > > > > - re-commit bug fixes that were committed after the merge
> > > > done
> > > > > - merge the 0.92 branch to trunk
> > > > done
> > > > > - fix the problems in trunk
> > > > and done except the problem was in the branch. I think it was a
> > > > manual
> > > > merge of mine gone wrong. Trunk should be clean.
> > > > We should make a patch release.
> > > > Mihael
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
Michael Wilde
