[Swift-devel] [Bug 227] New: Always keep submit and stdout/err files for failing jobs from localscheduler provider
    bugzilla-daemon at mcs.anl.gov
    Fri Oct  8 10:27:17 CDT 2010
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=227
           Summary: Always keep submit and stdout/err files for failing
           Product: Swift
           Version: unspecified
          Platform: All
        OS/Version: All
            Status: NEW
          Severity: normal
          Priority: P2
         Component: SwiftScript language
        AssignedTo: skenny at uchicago.edu
        ReportedBy: wilde at mcs.anl.gov
This should happen even without the debug=true flag in e.g.
etc/providers-pbs.properties.
Its possible that what Im seeing (ie that these files are not being retained)
is due to the fact the its a coaster worker job launch that Im current;y
debugging. But currently I need to keep setting debug-true to get these files
retained when the coaster worker job launch fails.
Its possible that the desired file retention is happening correctly for
ordinary PBS jobs.
Same applies to Condor and SGE local scheduler providers, and ideally to Globus
provider jobs.
Also the debug=true flag should be documented in a User Guide "Troubleshooting"
section.
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching the reporter.
