[Swift-devel] swift versions
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Thu Oct  7 16:08:07 CDT 2010
Yes, but I think that 1.0 is a release candidate- right?  New material
will go into trunk until we branch for 1.1 .
On Thu, 7 Oct 2010, Sarah Kenny wrote:
> sounds good.
> just want to verify (sorry to beat this to death):
> so, we alias the 'main guide' to 0.9 (as suggested) and any changes we make
> will go to the doc in branches/1.0 which will then be the new alias for the
> 'main guide' once we do the release.
> On Thu, Oct 7, 2010 at 3:45 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>> Yup.
>> On Thu, 7 Oct 2010, Mihael Hategan wrote:
>>  To summarize:
>>> There is a 1-1 mapping between branches and docs. One of the branches
>>> (corresponding to the current release) gets linked from "main" (i.e.
>>> main docs are the docs for the current release). So:
>>> branches/0.9 <-> 0.9 docs
>>> banches/0.8 <-> 0.8 docs
>>> trunk <-> trunk docs
>>> If current release is 0.9, then main docs = 0.9 docs.
>>> On Thu, 2010-10-07 at 15:30 -0500, Justin M Wozniak wrote:
>>>> I meant release branch.  The valid branches could be hard-coded into the
>>>> update.sh script.  The main guide would be the doc associated with the
>>>> current version.  So right now, "main guide" would be aliased to 0.9 .
>>>>  was thinking of what justin said, "I propose we have one web site but
>>>>> multiple docs/guides directories, all accessible from the docs/index.php
>>>>> page.  Each of these would be associated with a branch"
>>>>> i was assuming that whatever branch(es) these were associated with, that
>>>>> doc
>>>>> would somehow need to make its way to a main guide that we are pointing
>>>>> users to.
>>>>> On Thu, Oct 7, 2010 at 3:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
>>>>> wrote:
>>>>>  On Thu, 2010-10-07 at 14:55 -0500, Sarah Kenny wrote:
>>>>>>> so, in that case the 'main user doc' would be something *like*
>>>>>>> http://www.ci.uchicago.edu/swift/docs10/index.php ?
>>>>>>> and THAT would include the updates from all the current branches
>>>>>> define "all current branches". We have:
>>>>>> 1. Release branches
>>>>>> 2. Trunk
>>>>>> 3. Development branches (which are transient entities and only there to
>>>>>> make trunk's life easier).
>>>>>>   merged into it once we do a release?
>>>>>>> On Thu, Oct 7, 2010 at 2:42 PM, Mihael Hategan <hategan at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>        On Thu, 2010-10-07 at 14:39 -0500, Sarah Kenny wrote:
>>>>>>>     > so, in this scenario, the changes to the doc that exist in
>>>>>>>        each branch
>>>>>>>     > are pushed to the main user doc when we do the release or am
>>>>>>>        i missing
>>>>>>>     > a step here?
>>>>>>>        That or we really have no "main doc" and instead we link from
>>>>>>>        every
>>>>>>>        release. Though I feel odd about that.
>>>>>>>     > On Thu, Oct 7, 2010 at 2:34 PM, Mihael Hategan
>>>>>>>     > wrote:
>>>>>>>     >         On Thu, 2010-10-07 at 14:28 -0500, Justin M Wozniak
>>>>>>>     >      >> On Thu, Oct 7, 2010 at 1:08 PM, Mihael Hategan
>>>>>>>     >         <hategan at mcs.anl.gov> wrote:
>>>>>>>     >      >>> Right. I think 1.0/4.1.7 should go out soon.
>>>>>>>     >      >> ok, so i guess we should decide what 'soon'
>>>>>>>        means ;) i am
>>>>>>>     >         currently going
>>>>>>>     >      >> thru the old bugs in bugzilla (at least trying
>>>>>>>        to close
>>>>>>>     >         out things that have
>>>>>>>     >      >> been already fixed or are no-longer applicable,
>>>>>>>        etc), but
>>>>>>>     >         perhaps it would
>>>>>>>     >      >> be good to determine if there are bigger issues
>>>>>>>        outside of
>>>>>>>     >         that that still
>>>>>>>     >      >> need to be dealt with before we can put what
>>>>>>>        we've got
>>>>>>>     >         into a stable release
>>>>>>>     >      >> and determine a time-frame...anything come to
>>>>>>>        mind?
>>>>>>>     >      >> as far as documentation...does it make sense for
>>>>>>>        each
>>>>>>>     >         branch to have a full
>>>>>>>     >      >> copy of /ci/www/projects/swift under it which
>>>>>>>        can then be
>>>>>>>     >         merged with the
>>>>>>>     >      >> main/live copy whenever the code is merged?
>>>>>>>        admittedly, i
>>>>>>>     >         know nothing about
>>>>>>>     >      >> docbook, but from the standpoint of updating and
>>>>>>>        merging
>>>>>>>     >         this seems to make
>>>>>>>     >      >> sense to me (though feel free to suggest another
>>>>>>>        way :)
>>>>>>>     >      >> ~sk
>>>>>>>     >      > I was looking at the update.sh script earlier
>>>>>>>        today- I
>>>>>>>     >         propose we have one
>>>>>>>     >      > web site but multiple docs/guides directories, all
>>>>>>>     >         accessible from the
>>>>>>>     >      > docs/index.php page.  Each of these would be
>>>>>>>        associated with
>>>>>>>     >         a branch.
>>>>>>>     >      > So, similar to the existing "Historical" section
>>>>>>>        but for
>>>>>>>     >         "future" branches
>>>>>>>     >      > as well.  That would take a small modification to
>>>>>>>        the
>>>>>>>     >         update.sh script and
>>>>>>>     >      > manual modification of the docs/index.php page for
>>>>>>>        each
>>>>>>>     >         version number.
>>>>>>>     >      > We may also want to have the feature changes (past
>>>>>>>        and
>>>>>>>     >         future version
>>>>>>>     >      > numbers) available on that page but I think those
>>>>>>>        can be
>>>>>>>     >         plain text.
>>>>>>>     >      > These could be pulled directly from SVN as well.
>>>>>>>     >         I agree. I generally believe that documentation
>>>>>>>        should be kept
>>>>>>>     >         in sync
>>>>>>>     >         with releases (and I also think that the effort of
>>>>>>>        doing so is
>>>>>>>     >         minimal).
>> Justin M Wozniak
Justin M Wozniak
