[Swift-devel] new commits
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Oct  5 21:16:58 CDT 2010
On Tue, 2010-10-05 at 18:11 -0500, Sarah Kenny wrote:
> On Tue, Oct 5, 2010 at 4:13 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         >         I think I committed some changes based on your
>         patch. One
>         >         problem was
>         >         that gram2 doesn't seem to support a job name. Did
>         you find a
>         >         way around
>         >         that?
>         > hmm, it is working on abe (gram2) and queenbee
>         (gram5)...were you
>         > getting an error running it elsewhere or did it just not
>         pick up the
>         > name? i'm thinking if it works for some gram versions and
>         not others
>         > it might be ok to commit unless it actually causes an error
>         in
>         > versions where the name is not passed (?)
>         That was the problem. It caused an error.
> ok...do you know where you ran it that you were able to produce the
> error?
http://mail.ci.uchicago.edu/mailman/private/swift-devel/2010-August/006730.html
You may need a password for that archive, which I will disclose through
some other means. Otherwise subject was "gram2 coaster workers
terminating prematurely"
