[Swift-devel] new commits
    Sarah Kenny
    skenny at uchicago.edu
    Tue Oct  5 18:15:17 CDT 2010
On Tue, Oct 5, 2010 at 2:31 PM, Sarah Kenny <skenny at uchicago.edu> wrote:
> On Tue, Oct 5, 2010 at 12:58 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
>> I think I committed some changes based on your patch. One problem was
>> that gram2 doesn't seem to support a job name. Did you find a way around
>> that?
> hmm, it is working on abe (gram2) and queenbee (gram5)...were you getting
> an error running it elsewhere or did it just not pick up the name? i'm
> thinking if it works for some gram versions and not others it might be ok to
> commit unless it actually causes an error in versions where the name is not
> passed (?)
> i thought you had committed (or were going to commit) the change as well,
> but i'm not seeing it here:
> http://cogkit.svn.sourceforge.net/viewvc/cogkit/branches/4.1.7/src/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java?revision=2623&view=markup&pathrev=2623
> is there somewhere else i should be looking?
>> On Tue, 2010-10-05 at 12:26 -0500, Sarah Kenny wrote:
>> > hi all, i have a fix to swift that allows the jobName parameter to be
>> > passed to GRAM (so the job name actually shows up in the queue). this
>> > will be my first commit to the cog/swift source so i want to know
>> > where the best place is to do this? i'd like it to be in the stable
>> > release so that it's there when we update. my user group (HNL) has
>> > been using the stable branch with this fix added for several months so
>> > it's pretty well-tested.
>> > i guess the question is would it be best to commit this to the
>> > development code (which as i understand is cogkit/trunk/current) to be
>> > migrated to the stable code (cogkit/branches/4.1.7) in the near future
>> > when we decide to update the stable branch?
>> > also, i'm guessing i'll need to get access (from mihael or mike
>> > wilde?) to the cog source...
>> I can do that. Do you have a sourceforge account?
yes, user name is skenny24
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20101005/c975db28/attachment.html>
