[Swift-devel] new commits
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Oct  5 16:13:03 CDT 2010
On Tue, 2010-10-05 at 14:31 -0500, Sarah Kenny wrote:
> On Tue, Oct 5, 2010 at 12:58 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         I think I committed some changes based on your patch. One
>         problem was
>         that gram2 doesn't seem to support a job name. Did you find a
>         way around
>         that?
> hmm, it is working on abe (gram2) and queenbee (gram5)...were you
> getting an error running it elsewhere or did it just not pick up the
> name? i'm thinking if it works for some gram versions and not others
> it might be ok to commit unless it actually causes an error in
> versions where the name is not passed (?)
That was the problem. It caused an error.
> i thought you had committed (or were going to commit) the change as
> well, but i'm not seeing it here:
> http://cogkit.svn.sourceforge.net/viewvc/cogkit/branches/4.1.7/src/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java?revision=2623&view=markup&pathrev=2623
It's in trunk.
But:
http://cogkit.svn.sourceforge.net/viewvc/cogkit/trunk/current/src/cog/modules/provider-gt2/src/org/globus/cog/abstraction/impl/execution/gt2/JobSubmissionTaskHandler.java?r1=2815&r2=2867
> is there somewhere else i should be looking?
>         On Tue, 2010-10-05 at 12:26 -0500, Sarah Kenny wrote:
>         > hi all, i have a fix to swift that allows the jobName
>         parameter to be
>         > passed to GRAM (so the job name actually shows up in the
>         queue). this
>         > will be my first commit to the cog/swift source so i want to
>         know
>         > where the best place is to do this? i'd like it to be in the
>         stable
>         > release so that it's there when we update. my user group
>         (HNL) has
>         > been using the stable branch with this fix added for several
>         months so
>         > it's pretty well-tested.
>         > i guess the question is would it be best to commit this to
>         the
>         > development code (which as i understand is
>         cogkit/trunk/current) to be
>         > migrated to the stable code (cogkit/branches/4.1.7) in the
>         near future
>         > when we decide to update the stable branch?
>         > also, i'm guessing i'll need to get access (from mihael or
>         mike
>         > wilde?) to the cog source...
>         I can do that. Do you have a sourceforge account?
