[Swift-devel] Re: Problems with provider.staging.pin.swiftfiles
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Mon Nov 22 16:31:38 CST 2010
Hello
 	This should be corrected in trunk now.
 	Justin
On Thu, 11 Nov 2010, Justin M Wozniak wrote:
> Hello
> 	Yes, this was broken a few weeks ago- I will try to restore it ASAP.
> (Cf. swift-devel post from 9/27.)
> 	Justin
> On Thu, 11 Nov 2010, Michael Wilde wrote:
>> Justin,
>> When Tom Uram turns on this option and runs a simple test script (a foreach
>> and an app that just collects node info), he gets an error "520" returned
>> in the swift log, as if from the app. I am thinking that the 520 is somehow
>> coming from worker.
>> This is going from bridled to Eureka worker nodes, with provider staging
>> turned on in proxy mode.
>> When we set provider.staging.pin.swiftfiles to false, the script runs ok.
>> We'll need to collect and send logs and a test case, but I wanted to alert
>> you to a potential problem with this feature.
>> - Mike
Justin M Wozniak
