[Swift-devel] Re: Notes on maintaining the swift web and docs
wilde at mcs.anl.gov
Thu May 27 09:49:43 CDT 2010
David, here's what I think may fix the diamond problem:
On Oct 13, 2009, at 11:25 PM, Michael Wilde wrote:
> Rob, I think I found the param that makes it go away (ie gens the
> html pages in UTF-8 encoding.
> It was:
> com$ pwd
> /ci/www/projects/osgedu/build/docbook-xsl/html
> com$ diff chunker.xsl chunker.xsl.orig
> 28,29c28
> < <xsl:param name="chunker.output.origencoding"
> select="'ISO-8859-1'"/>
> < <xsl:param name="chunker.output.encoding" select="'UTF-8'"/>
> > <xsl:param name="chunker.output.encoding" select="'ISO-8859-1'"/>
> com$
> Does this fix it on all of the pages?
> gridcolombia looks OK to me now as did other things I spot checked.
> After changing the file chunker.xsl above, I just did /ci/www/
> projects/osgedu/update.sh
- Mike
----- "David Kelly" <dk0966 at cs.ship.edu> wrote:
> Hello all,
> I have been trying to generate the Swift docs with docbook, but am
> having only partial success. If anyone happens to be familiar with
> this process, any help would be appreciated.
> I have read the README and wiki link that Michael sent, but there are
> still a few issues. Here is an overview of everything I have done thus
> far:
> After making some changes to the documentation, I created a symlink to
> docbooks.
> I have formatting/docbooks pointing to
> /home/hategan/docbook/docbook-xsl.
> I have tried all of the other docbook directories mentioned in the
> readme and wiki, but they all seem to behave the same
> Next when I attempted to run buildguides.sh I got an error message
> that fop/fop.sh was not found.
> I found /home/hategan/fop.tar.gz and uncompressed it into the doc
> directory.
> That got rid of the fop errors, but then I received "Error: JAVA_HOME
> is not defined correctly"
> Then I followed a maze of symlinks to what I believe is the correct
> JAVA_HOME on this system ( login.ci.uchicago.edu ) at
> /usr/lib/jvm/jre-1.4.2-gcj
> Then I received the following errors:
> [INFO] Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
> [Fatal Error] refentry.xsl:314:58: The string "--" is not permitted
> within comments.
> [ERROR] javax.xml.transform.TransformerConfigurationException:
> javax.xml.transform.TransformerException:
> org.xml.sax.SAXParseException: The string "--" is not permitted within
> comments.
> make: *** [userguide.pdf] Error 2
> I tracked refentry.xsl down and found it in
> /usr/share/apps/ksgmltools2/docbook/xsl/html/refentry.xsl.
> I could try to modify the comments but I do not have permission. The
> error is preventing pdf files from being created.
> After this section fails, it moves to create the PHP files. The PHP
> files get created, and works for the most part except for one nagging
> problem.
> Next to each section number (1.1, 1.2, etc) a diamond with a question
> mark inside of it appears.
> I double checked that they do not exist in the xml file, only the php
> file
> I think this is some strange character map issue. The PHP file sets
> the character set to UTF-8. When I change firefox to render the page
> in ISO8859-15 it works fine.
> I have tried changing the character set of the php file, and also
> tried setting the character set through .htaccess with no luck (the
> pages are being served out of my public_html directory for testing)
> Any other ideas and suggestions would be appreciated.
> Thanks!
> Regards,
> David
> Message: 2
> Date: Tue, 25 May 2010 19:18:57 -0500 (CDT)
> From: Michael Wilde < wilde at mcs.anl.gov >
> Subject: [Swift-devel] Notes on maintaining the swift web and docs
> To: Swift Devel < swift-devel at ci.uchicago.edu >
> Message-ID: <5124436.99271274833137828.
> JavaMail.root at zimbra>
> Content-Type: text/plain; charset=utf-8
> To help David in creating a procedure for test copies of the Swift web
> and for generating the Swift docs with docbook, I placed notes gleaned
> from swift-devel at:
> http://www.ci.uchicago.edu/wiki/bin/view/SWFT/MaintainingSwiftWebContent
> If anyone has tips to refine those instructions, please update that
> page or post suggestions here for David to try and then post for
> general use.
> As suggested on that page, most of the notes should wind up in README
> files at www/ and docs/
> - Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
