[Swift-devel] provider-condor submit file generation
Allan Espinosa aespinosa at cs.uchicago.edu
Mon May 17 19:14:29 CDT 2010
I was poking around the provider-condor source tree today.
provider-condor/src/org/globus/cog/abstraction/impl/execution/condor/DescriptionFileGenerator.java:33+:
    private static void constructDescriptionFile(File descriptionFile,
Task task)
            throws IOException {
        JobSpecification specification = (JobSpecification) task
                .getSpecification();
        FileWriter fileWriter = new FileWriter(descriptionFile);
        fileWriter.write("#####################################\n");
        fileWriter.write("# Task ID: " + task.getIdentity().toString() + "\n");
        fileWriter.write("#####################################\n\n");
        String executable = specification.getExecutable();
        if (executable != null) {
            fileWriter.write("Executable = " + executable + "\n");
        String argumentString = specification.getArgumentsAsString();
        argumentString = argumentString.replaceAll("\\\"", "\\\\\"");
        if (argumentString != null) {
            fileWriter.write("Arguments = " + argumentString + "\n");
But when I looked at a generated condor-g job in my workflow i got:
universe = grid
grid_resource = gt2 ff-grid.unl.edu/jobmanager
stream_output = False
stream_error  = False
Transfer_Executable = false
output = /home/aespinosa/workflows/cybershake/condorg/res_testjob.submit.stdout
error = /home/aespinosa/workflows/cybershake/condorg/res_testjob.submit.stderr
log = /home/aespinosa/workflows/cybershake/condorg/res_testjob.submit.log
remote_initialdir =
/panfs/panasas/CMS/data/engage-aespinosa/swift/postproc-fireflyg_small
executable = /bin/bash
arguments = /panfs/panasas/CMS/data/engage-aespinosa/swift/postproc-fireflyg_small/shared/_swiftwrap
extract-mo6464sj -jobdir m -scratch  -e
/panfs/panasas/CMS/app/engage-aespinosa/JBSim3d/bin/jbsim3d -out
stdout.txt -err stderr.txt -i -d
TEST|158/0|panfs/panasas/CMS/data/engage-aespinosa/swift/158/0 -if
TEST/TEST_fy_644.sgt|TEST/TEST_fx_644.sgt|158/0/158_0.txt.variation-s0001-h0000
-of panfs/panasas/CMS/data/engage-aespinosa/swift/158/0/TEST_158_0_subfy.sgt|panfs/panasas/CMS/data/engage-aespinosa/swift/158/0/TEST_158_0_subfx.sgt
-k  -cdmfile fs.data -status files -a stat=TEST extract_sgt=1
slon=-118.286 slat=34.0192
rupmodfile=158/0/158_0.txt.variation-s0001-h0000
sgt_xfile=TEST/TEST_fx_644.sgt sgt_yfile=TEST/TEST_fy_644.sgt
extract_sgt_xfile=panfs/panasas/CMS/data/engage-aespinosa/swift/158/0/TEST_158_0_subfx.sgt
extract_sgt_yfile=panfs/panasas/CMS/data/engage-aespinosa/swift/158/0/TEST_158_0_subfy.sgt
notification = Never
leave_in_queue = TRUE
queue
I was at least expecting to the the line to start with '##### ...\n #
Task : ..." .  Is there another place I should poke around to figure
out the jobspec to condor submit file? Like where does "jobType=grid"
get translated to "Universe=grid"?
Thanks!
-Allan
