[Swift-devel] error in reading in files over gridftp
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Wed Mar 24 17:48:41 CDT 2010
Just created the said file in the home directory.  I tried using both
single slash and two slashes.   Both gave the same errors
still no good :(
swift-r3264 cog-r2728
RunID: test
Progress:
Progress: Failed but can retry:1
Failed to transfer wrapper log from
071-singlefilemapper-input-test/info/4 on localhost
Execution failed:
        Exception in echo:
Arguments: [panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in]
Host: localhost
Directory: 071-singlefilemapper-input-test/jobs/4/echo-44t4bkpj
stderr.txt:
stdout.txt:
Caused by:
        Exception in getFile
Caused by:
        Server refused performing the request. Custom message:  (error
code 1) [Nested exception message:  Custom message: Unexpected reply:
500 Command failed]
2010/3/24 Mihael Hategan <hategan at mcs.anl.gov>:
> No good.
> So, maybe there's one more thing to try, for completeness.
> If you put the file in
> ~/panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in and
> revert to the first form (i.e. 2 slashes), does that work?
> On Wed, 2010-03-24 at 17:27 -0500, Allan Espinosa wrote:
>> the argument passed to the app gets prefixed another slash (both in
>> the session output and logfile)
>> RunID: test
>> Progress:
>> 071-singlefilemapper-input-test/info/n on localhost
>> Execution failed:
>>         Exception in echo:
>> Arguments: [/panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in]
>> Host: localhost
>> Directory: 071-singlefilemapper-input-test/jobs/n/echo-nvkbakpj
>> stderr.txt:
>> stdout.txt:
>> Caused by:
>> Caused by:
>> 500 Command failed]
>> > What happens if you add another forward slash after ".edu"?
>> > On Wed, 2010-03-24 at 16:31 -0500, Allan Espinosa wrote:
>> >> The file gets created in the work directory (probably via touch) but
>> >> has 0 bytes for size.
>> >> type messagefile;
>> >> (messagefile o) write(messagefile i) {
>> >>     app {
>> >>         echo @filename(i) stdout=@filename(o);
>> >> messagefile infile
>> >> <"gsiftp://ff-grid.unl.edu//panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in">;
>> >> messagefile outfile <"071-singlefilemapper-input.out">;
>> >> outfile = write(infile);
>> >> session (with vanilla sites.xml):
>> >> RunID: test
>> >> Progress:
>> >> 071-singlefilemapper-input-test/info/e on localhost
>> >> 071-singlefilemapper-input-test/info/g on localhost
>> >> Progress:  Stage in:1
>> >> 071-singlefilemapper-input-test/info/i on localhost
>> >> Execution failed:
>> >>         Exception in echo:
>> >> Host: localhost
>> >> Directory: 071-singlefilemapper-input-test/jobs/i/echo-ic8o7kpj
>> >> stderr.txt:
>> >> stdout.txt:
>> >> Caused by:
>> >> Caused by:
>> >> 500 Command failed]
>> >> What command does getFile issue?  I can download the file manually via
>> >> globus-url-copy or uberftp
>> >> the logfile is also attached in this email.
>> >> thanks!
>> >> -Allan
