[Swift-devel] error in reading in files over gridftp
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Mar 24 17:32:20 CDT 2010
No good.
So, maybe there's one more thing to try, for completeness.
If you put the file in
~/panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in and
revert to the first form (i.e. 2 slashes), does that work?
On Wed, 2010-03-24 at 17:27 -0500, Allan Espinosa wrote:
> the argument passed to the app gets prefixed another slash (both in
> the session output and logfile)
> swift-r3264 cog-r2728
> RunID: test
> Progress:
> Progress: Failed but can retry:1
> Failed to transfer wrapper log from
> 071-singlefilemapper-input-test/info/n on localhost
> Execution failed:
>         Exception in echo:
> Arguments: [/panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in]
> Host: localhost
> Directory: 071-singlefilemapper-input-test/jobs/n/echo-nvkbakpj
> stderr.txt:
> stdout.txt:
> Caused by:
>         Exception in getFile
> Caused by:
>         Server refused performing the request. Custom message:  (error
> code 1) [Nested exception message:  Custom message: Unexpected reply:
> 500 Command failed]
> 2010/3/24 Mihael Hategan <hategan at mcs.anl.gov>:
> > What happens if you add another forward slash after ".edu"?
> > On Wed, 2010-03-24 at 16:31 -0500, Allan Espinosa wrote:
> >> The file gets created in the work directory (probably via touch) but
> >> has 0 bytes for size.
> >> type messagefile;
> >> (messagefile o) write(messagefile i) {
> >>     app {
> >>         echo @filename(i) stdout=@filename(o);
> >> messagefile infile
> >> <"gsiftp://ff-grid.unl.edu//panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in">;
> >> messagefile outfile <"071-singlefilemapper-input.out">;
> >> outfile = write(infile);
> >> session (with vanilla sites.xml):
> >> RunID: test
> >> Progress:
> >> 071-singlefilemapper-input-test/info/e on localhost
> >> 071-singlefilemapper-input-test/info/g on localhost
> >> Progress:  Stage in:1
> >> 071-singlefilemapper-input-test/info/i on localhost
> >> Execution failed:
> >>         Exception in echo:
> >> Arguments: [panfs/panasas/CMS/data/engage/swift/071-singlefilemapper-input.in]
> >> Host: localhost
> >> Directory: 071-singlefilemapper-input-test/jobs/i/echo-ic8o7kpj
> >> stderr.txt:
> >> stdout.txt:
> >> Caused by:
> >> Caused by:
> >> 500 Command failed]
> >> What command does getFile issue?  I can download the file manually via
> >> globus-url-copy or uberftp
> >> the logfile is also attached in this email.
> >> thanks!
> >> -Allan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
