[Swift-devel] coasters and java on queen bee
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jun 29 11:28:15 CDT 2010
Assuming you are starting coasters via GT2, I would suggest a few experiments with globus-job-rub to see how your path is being set up.
Similarly if you are running locally or via ssh.
I had similar problems on Abe quite a while ago, which is configured much like QueenBee, but much has changed since then both in coasters and possibly on the systems.
I suspect we need to debug a bit more ourselves before we go to the sysadmins.
- Mike
----- "Sarah Kenny" <skenny at uchicago.edu> wrote:
> pre-pending the path via .bashrc,tc.data or sites.xml seems to have
> no
> effect...i was under the impression that others were successfully
> running coasters on queen bee, so thought someone might've dealt with
> this already...but perhaps i should try poking the loni admins to see
> if they can shed some light.
> thanks
> ~sk
> On Tue, Jun 29, 2010 at 10:39 AM, Michael Wilde <wilde at mcs.anl.gov>
> wrote:
> > It seems like some interaction between coaster bootstrap, softenv
> (or lack thereof) and site conventions is causing gcj to be used. That
> seems to be in your PATH and you can try to explicitly put the correct
> JAVA in your PATH in .bashrc and/or .profile. Setting JAVA_HOME alone
> wont cause the correct Java to be run.
> > - Mike
> >> nope :(
> >> On Mon, Jun 28, 2010 at 2:40 PM, Mihael Hategan
> <hategan at mcs.anl.gov>
> >> wrote:
> >> > Ok. That might not work either.
> >> > However, you may try to add the proper java executable to the
> PATH.
> >> I
> >> > think that might work better.
> >> > On Mon, 2010-06-28 at 14:34 -0500, Sarah Kenny wrote:
> >> >> tc.data had no effect...will try sites
> >> >> On Mon, Jun 28, 2010 at 2:30 PM, Mihael Hategan
> >> <hategan at mcs.anl.gov> wrote:
> >> >> > Have you tried setting JAVA_HOME in tc.data or sites.xml? I
> have
> >> a
> >> >> > suspicion that might work.
> >> >> > On Mon, 2010-06-28 at 14:11 -0500, Sarah Kenny wrote:
> >> >> >> anyone else get this using coasters on queen bee?
> >> >> >> STDOUT: Warning: -jar not understood. Ignoring.
> >> >> >> Exception in thread "main" java.lang.NoClassDefFoundError:
> >> .tmp.bootstrap.Z29712
> >> >> >>    at gnu.gcj.runtime.FirstThread.run()
> >> (/usr/lib64/libgcj.so.5.0.0)
> >> >> >>    at _Jv_ThreadRun(java.lang.Thread)
> >> >> >>    at _Jv_RunMain(java.lang.Class, byte const, int, byte
> const,
> >> >> >> boolean) (/usr/lib64/libgcj.so.5.0.0)
> >> >> >>    at __gcj_personality_v0 (/home/skenny/java.version=1.4.2)
> >> >> >>    at __libc_start_main (/lib64/tls/libc-2.3.4.so)
> >> >> >>    at _Jv_RegisterClasses (/home/skenny/java.version=1.4.2)
> >> >> >> not sure why it's showing my java version as 1.4.2...when
> i'm
> >> logged
> >> >> >> into the headnode (or a worker node) my java version is much
> >> newer:
> >> >> >> [skenny at qb1 ~]$ java -version
> >> >> >> java version "1.6.0_20"
> >> >> >> Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
> >> >> >> Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed
> mode)
> >> >> >> i also tried adding JAVA_HOME to my .bashrc on the site
> which
> >> had no effect.
> >> >> >> any idea how i can get swift to use the right java?
> >> >> >> using a slightly older swift (swift-r3116 cog-r2482)...don't
> >> know if
> >> >> >> this has maybe been fixed in a later version (?)
> >> >> >> thanks
> >> >> >> ~sk
> >> >> >> _______________________________________________
> >> >> >> Swift-devel mailing list
> >> >> >> Swift-devel at ci.uchicago.edu
> >> >> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
