[Swift-devel] coasters and java on queen bee
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jun 29 10:39:03 CDT 2010
It seems like some interaction between coaster bootstrap, softenv (or lack thereof) and site conventions is causing gcj to be used. That seems to be in your PATH and you can try to explicitly put the correct JAVA in your PATH in .bashrc and/or .profile. Setting JAVA_HOME alone wont cause the correct Java to be run.
- Mike
----- "Sarah Kenny" <skenny at uchicago.edu> wrote:
> nope :(
> On Mon, Jun 28, 2010 at 2:40 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > Ok. That might not work either.
> > However, you may try to add the proper java executable to the PATH.
> I
> > think that might work better.
> > On Mon, 2010-06-28 at 14:34 -0500, Sarah Kenny wrote:
> >> tc.data had no effect...will try sites
> >> On Mon, Jun 28, 2010 at 2:30 PM, Mihael Hategan
> <hategan at mcs.anl.gov> wrote:
> >> > Have you tried setting JAVA_HOME in tc.data or sites.xml? I have
> a
> >> > suspicion that might work.
> >> > On Mon, 2010-06-28 at 14:11 -0500, Sarah Kenny wrote:
> >> >> anyone else get this using coasters on queen bee?
> >> >> STDOUT: Warning: -jar not understood. Ignoring.
> >> >> Exception in thread "main" java.lang.NoClassDefFoundError:
> .tmp.bootstrap.Z29712
> >> >>    at gnu.gcj.runtime.FirstThread.run()
> (/usr/lib64/libgcj.so.5.0.0)
> >> >>    at _Jv_ThreadRun(java.lang.Thread)
> >> >>    at _Jv_RunMain(java.lang.Class, byte const, int, byte const,
> >> >> boolean) (/usr/lib64/libgcj.so.5.0.0)
> >> >>    at __gcj_personality_v0 (/home/skenny/java.version=1.4.2)
> >> >>    at __libc_start_main (/lib64/tls/libc-2.3.4.so)
> >> >>    at _Jv_RegisterClasses (/home/skenny/java.version=1.4.2)
> >> >> not sure why it's showing my java version as 1.4.2...when i'm
> logged
> >> >> into the headnode (or a worker node) my java version is much
> newer:
> >> >> [skenny at qb1 ~]$ java -version
> >> >> java version "1.6.0_20"
> >> >> Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
> >> >> Java HotSpot(TM) 64-Bit Server VM (build 16.3-b01, mixed mode)
> >> >> i also tried adding JAVA_HOME to my .bashrc on the site which
> had no effect.
> >> >> any idea how i can get swift to use the right java?
> >> >> using a slightly older swift (swift-r3116 cog-r2482)...don't
> know if
> >> >> this has maybe been fixed in a later version (?)
> >> >> thanks
> >> >> ~sk
> >> >> _______________________________________________
> >> >> Swift-devel mailing list
> >> >> Swift-devel at ci.uchicago.edu
> >> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
