[Swift-devel] Fwd: How to know if a site requires a VOMS Proxy or a Grid Proxy for authentication?
wilde at mcs.anl.gov wilde at mcs.anl.gov
Thu Jun 17 15:09:32 CDT 2010
More from the OSG thread, related to the discussion on VOMS proxy issues.
The full thread should be somewhere below here:
  http://listserv.fnal.gov/scripts/wa.exe?A1=ind1006c&L=osg-int
----- Forwarded Message -----
To: "Brian Bockelman" <bbockelm at cse.unl.edu>
Cc: "Keith Chadwick" <chadwick at fnal.gov>, "Iwona Sakrejda" <isakrejda at lbl.gov>, OSG-int at opensciencegrid.org, OSG-VO-FORUM at opensciencegrid.org, "Arvind Gopu" <agopu at indiana.edu>, "Rob Quick" <rquick at iupui.edu>
Sent: Thursday, June 17, 2010 2:58:06 PM GMT -06:00 US/Canada Central
Subject: Re: How to know if a site requires a VOMS Proxy or a Grid Proxy for authentication?
Hey Brian,
    you misunderstood me. I am concerned about users of VOs that do not
provide a VOMS Server and that can not generate proxies with extended
attributes. The voms proxy without attributes will be of little use if
the remote site ( for instance Fermilab ) requires it.
My initial goal was to direct the user to some information that would
allow him to find out what the remote site requires. Otherwise the only
way to find out for a user is to try and open a ticket if he fails in
all possible ways (grid-proxy, voms-proxy w/o attributes, voms-proxy
with attributes ).
Robert
Brian Bockelman wrote:
> On Jun 17, 2010, at 12:39 AM, Robert Engel wrote:
>> Keith,
>>   thanks for the link. But that is what I meant by manually knocking on each door. As an OSG user I want a simple way to find out what proxy to use on each of the potential 50+ resources there are.
> Use a VOMS proxy.  Didn't we just determine they are a superset of grid proxies?  Reading through the thread, I didn't see any site saying "I accept grid proxies but not VOMS proxies."
> Ultimately, there are a million things that can go wrong in distributed computing (cosmic rays hitting fiber cables at FNAL).  Why concentrate on this one?  I'm not against having better probes or tests - but we have extremely limited effort.  I'd rather identify the areas where we need this the most.
> The only way to know if a site accepts your jobs are to submit jobs.  Why should we add central complexity instead of using auto-discovery (esp since the central view, whether MyOSG, BDII, etc, is always going to be wrong as they don't use your proxy)?
> We are a decentralized, distributed computing facility.  You can't have centralized information that's "correct" if you have a decentralized computing system.
> Brian
>> I am thinking that myOSG could provide the required proxy information for each of the resources. Perhaps Arvind and Rob can comment on that.
>> Robert
>> Keith Chadwick wrote:
>>> At 3:17 PM -0700 6/16/10, Robert Engel wrote:
>>>> Hey Iwona,
>>>>   currently I recommend in the documentation to always check with the membership VO if they support VOMS and provide a VOMS server. Just as you said, the VOMS proxy in the end is just a 'fancy' grid proxy and can be used as such. I recommend using the VOMS Proxy under this circumstances.
>>>> On the other hand I would like users who can't generate a VOMS Proxy with extended attributes to know if a certain site requires such without having to 'knock on every door' manually? Like for instance at Fermilab where this is required. I only know it is required because I talked to Burt. Otherwise I would have no idea.
>>> The requirement for voms proxies is explicitly published in the
>>> FermiGrid policy document:
>>>    http://fermigrid.fnal.gov/policy.html
>>> Direct quote from the above document:
>>>    VOs and VO members that desire to Fermilab grid resources must initialize
>>>    their credentials using:
>>>        * $VDT_LOCATION/voms/bin/voms-proxy-init
>>>    Those VOs and VO members that fail to use voms-proxy-init may be blocked
>>>    from accessing Fermilab grid resources.
>>> -Keith.
>>>> Thanks,
>>>> Robert
>>>> Iwona Sakrejda wrote:
>>>>> But even not all the sites that run GUMS servers requirer VOMS proxy.
>>>>> So I'd say - if a proxy is rejected by a site, is the error message clear? I never tried....
>>>>> Also the user should check with the VO. If a vo is utilizing functionality that comes with
>>>>> a VOMS proxy, it will be presumably educating its users about available roles and such, no?
>>>>> Always asking for a VOMS proxy is safer. If no VOMS server available - it will be reduced to
>>>>> a regular proxy. If a site is using map files, the extra stuff will be ignored and the proxy will
>>>>> work anyway.
>>>>> Isn't it so?
>>>>> Iwona
>>>>> On Wed, Jun 16, 2010 at 2:57 PM, Robert Engel <engel_r at ligo.caltech.edu <mailto:engel_r at ligo.caltech.edu>> wrote:
>>>>>    Steven,
>>>>>    ? Do you know how a user could find out what RSV probes are
>>>>>    running on any given site? I tried to find this in myOSG, but
>>>>>    nothing turned up.
>>>>>    Thanks,
>>>>>    Robert
>>>>>    Steven Timm wrote:
>>>>>        The answer is not always a clear yes or no. ?If a site copies
>>>>>        the OSG GUMS template and runs GUMS then they will end up
>>>>>        requiring voms proxies for about half of the VO's and not
>>>>>        for the other half.
>>>>>        You could indirectly find out by which RSV probes any given site
>>>>>        is running, GUMS sites run different RSV probes than grid-mapfile
>>>>>        sites do. ?by default all grid-mapfile sites do not require
>>>>>        any VOMS proxy.
>>>>>        FermiGrid is the only site I know of that requires VOMS proxy for
>>>>>        everyone and even we have a way to make exceptions if necessary.
>>>>>        Steve
>>>>>        On Wed, 16 Jun 2010, Robert Engel wrote:
>>>>>            Hello,
>>>>>            ?I am writing documentation for end users. I would like to
>>>>>            write how a user can find out if a site accepts a Grid
>>>>>            Proxy or requires a VOMS Proxy. Can that information be
>>>>>            found in myOSG?
>>>>>            Thanks,
>>>>>            Robert
>>>> Attachment converted: Macintosh HD:engel_r 18.vcf (TEXT/ttxt) (0040AFA0)
>> <engel_r.vcf>
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
