[Swift-devel] Re: Using coaster provider with jobmanager ssh:pbs
    Arjun Comar
    mandaya at rose-hulman.edu
    Fri Jun  4 23:32:41 CDT 2010
Just realized I only sent this to Mike. I'm resending it to swift-devel.
On Fri, Jun 4, 2010 at 10:11 PM, Arjun Comar <mandaya at rose-hulman.edu>wrote:
> Nope, no luck. Here's grid-proxy-info from both:
> pads:
> subject  : /DC=org/DC=doegrids/OU=People/CN=Arjun Comar 693820/CN=53942264
> issuer   : /DC=org/DC=doegrids/OU=People/CN=Arjun Comar 693820
> identity : /DC=org/DC=doegrids/OU=People/CN=Arjun Comar 693820
> type     : RFC 3820 compliant impersonation proxy
> strength : 512 bits
> path     : /tmp/x509up_u1857
> timeleft : 11:52:08
> bridled:
> 693820/CN=1363223477
> strength : 512 bits
> timeleft : 11:57:52
> Used the same passphrase to get both proxies,and set no options on
> grid-proxy-init.
> Arjun
> On Fri, Jun 4, 2010 at 9:00 PM, wilde at mcs.anl.gov <wilde at mcs.anl.gov>wrote:
>> When you use this configuration for running jobs from a submit host to a
>> PBS cluster using ssh to launch the coaster service on the PBS login host,
>> you need to create a GSI proxy (using grid-proxy-init) on both the client
>> and on the remote login host, using the same certificate.
>>  <pool handle="coasterpads">
>>   <execution provider="coaster" url="login1.pads.ci.uchicago.edu"
>> jobmanager="ssh:pbs"/>
>>   <profile namespace="globus" key="maxtime">3000</profile>
>>   <profile namespace="globus" key="workersPerNode">8</profile>
>>   <profile namespace="globus" key="slots">1</profile>
>>   <profile namespace="globus" key="nodeGranularity">1</profile>
>>   <profile namespace="globus" key="maxNodes">1</profile>
>>   <profile namespace="globus" key="queue">fast</profile>
>>   <profile namespace="karajan" key="jobThrottle">0.5</profile>
>>   <profile namespace="karajan" key="initialScore">10000</profile>
>>   <filesystem provider="ssh" url="login1.pads.ci.uchicago.edu"/>
>>   <workdirectory>/home/wilde/swift/lab</workdirectory>
>>  </pool>
>> Arjun, this is, I think, what was causing your workflow to fail.
>> I thought, that in the past, we used to get at least a GSI (grid security
>> infrastructure) error in the detailed log file. But I don't see that in this
>> case.
>> Let me know if creating proxies on both sides works for you. Be sure to
>> create it on the right PADS login host.
>> David and Arjun, can you coordinate on integrating this use case into the
>> tutorial (and eventually the Users Guide)? I suggested we do a series of
>> "profiles" (with diagrams) to show the various ways of running Swift locally
>> and remotely, and provide accompanying site file entries. Dennis, when you
>> get started next week and try these cases, we'll want to find a way to do
>> automated tests for them.
>> Thanks,
>> Mike
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
> Arjun Comar, Rose-Hulman '12
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20100604/cd4273ec/attachment.html>
