[Swift-devel] stuff to do
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Jul 15 18:35:49 CDT 2010
Most of the problems that were obvious with coaster file staging should
be fixed now. I ran a few tests for 1024 cat jobs on TP with ssh:pbs
with 2-8 workers/node (such that "concurrent" workers are tested) and it
consistently seemed fine.
I also quickly made a fake provider and I am getting a rate of about 100
j/s. So that seems not to infirm my previous suspicion.
On Mon, 2010-07-12 at 11:52 -0500, Michael Wilde wrote:
> Here's my view on these:
> > 2. test/fix coaster file staging
> This would be useful for both real apps and (I think) for CDM testing. I would do this first.
> I would then add:
> 5. Adjustments needed, if any, on multicore handling in PBS and SGE provider.
> 6. Adjustments and fixes for reliability and logging, if needed, in Condor-G provider.
> I expect that 5 & 6 would be small tasks, and they are not yet clearly defined. I think that other people could do them.
> Maybe add:
> 7. -tui fixes. Seems not to be working so well on recent tests; several of the screens, including the source-code view, seem not to be working.
> Then:
> > 1. make swift core faster
> I would do this second; I think you said you need about 7-10 days to try things and see what can be done, maybe more after that if the exploration suggests things that will take much (re)coding?
> > 3. standalone coaster service
> The current manual coasters is proving useful.
> > 4. swift shell
> Lets defer (4) for now; if we can instead run swift repeatedly and either have the coaster worker pool re-connect quickly to each new swift, or quickly start new pools within the same cluster job(s), that would suffice for now.
> Justin, do you want to weigh in on these?
> Thanks,
> Mike
> > The idea is that some recent changes may have shifted the existing
> > priorities. So think of this from the perspective of
> > user/application/publication goals rather than what you think would
> > be
> > "nice to have".
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
